engine light ON>>>need code help>>>cabbage007 10-03-2004, 05:38 PM While on the interstate...i used my cruise control and had the a/c on and noticed by blazer getting real sluggish and struggling to keep the "speed"..engine light came on and the code was...po410..p for powertrain..o for sae...4 for aux,emission cont....1 for fuel and air metering...0 for reserved.(code=secondary air injection system)..the blazer runs better now ..but the engine light still comes on ...with same code....mechanic on saturday said he couldn't find a problem..help :screwy: BlazerLT 10-03-2004, 07:06 PM Secondary Air injection system Malfunction Replace the electric air pump, solenoid valve, (under the rt. bottom of rad. support.) Also replace the check valve on lt.rear side of engine. You will also need to locate the 30A fuse behind the battery and replace it because the pump takes it out. Parts come from GM only, and will run about $250 for all. Disconnect battery for 10 mins. after to reset cabbage007 10-03-2004, 09:24 PM Secondary Air injection system Malfunction Replace the electric air pump, solenoid valve, (under the rt. bottom of rad. support.) Also replace the check valve on lt.rear side of engine. You will also need to locate the 30A fuse behind the battery and replace it because the pump takes it out. Parts come from GM only, and will run about $250 for all. Disconnect battery for 10 mins. after to reset thank you very much.... BlazerLT 10-03-2004, 09:27 PM ur velcome ;) rampolaris1 02-26-2005, 01:25 PM Did this do the trick for your blazer? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
