Tick or Knock noise
Google
Web AF
almost4
10-02-2004, 02:47 PM
I have 2000 Silver 5.3l 107,000 miles, at about 2,000 rpm I get a ticking noise like lifter noise. My question is there any way to adjust lifters or rockers to quiet this down. It is coming from driver side of engine sounding just like right under rockers but from inside the truck it sounds like exhaust leak or something. Any help much thanks.
almost4
10-06-2004, 11:24 PM
Still wondering
jumpingjack66
10-07-2004, 12:08 AM
Mine does that but i think its the piston slap prob;lem these trucks have. GM wont fix it so ill just live with it...JJ
elopez2
01-03-2005, 02:03 PM
I have the same problem with mine I have a 2001 silverado 4.8 engine and I hace the same problem it sounds like a lifter let me know if you find a fix I will let u know if I fing one Thanks.
mekinic
01-03-2005, 02:23 PM
my 99 did the same thing. I just changed the grade of gas and it went away.
mekinic
01-03-2005, 02:24 PM
My 99 did the same. I just changed the grade of gas and it went away.
elopez2
01-04-2005, 06:26 PM
There's no way to adjust does rocker arms they are Hydrolic you can take try to take out the Valve cover and make sure nothing is lose or that a rocker arm is broken I really dought they are losse or cracked the torque Spec on does are 22 ft-lbs. Talked to several mechanics and told me I have a bad Valve lifter. But my next ? is to change out the lifters I have to take out the Head and intake or I just have to take out the Intake?
silveradoman
01-05-2005, 12:10 AM
I just experienced this issue this weeked, at 2000 rpm (and around 140km/h) (bless that ambulance on the highway, everybody was going over 140km/h) :evillol:
I was running it on 86 octane gas though, IŽll do it again running on propane to see if the sound lingers.
internic
01-08-2005, 04:17 AM
to replace the hydraulic roller lifters in a vortec v8 you have to remove the intake manifold and then the cylinder heads. under the cylinder heads you have to remove these little retainers that keep the lifters in. THEN... you can pull the lifters out. easy huh? lol. be sure to soak new lifters in oil for a while before installation.
elopez2
01-11-2005, 05:37 PM
Has any body had any issues with this kind of noise I still haven't changed out the lifters. I really don't know what it is. U get this noise on the driver's side when U are going 2,000 rpm or above, it kind of sounds like a lifter. I open up the valve cover and didn't see anything lose, check and verify that rocker arms weren't lose check torque spec(22 ft-lbs). I think I'm going to take it to a mechanic. Before I do does anybody had any problems or had the same issue??????
kenny-1907
01-11-2005, 05:43 PM
I am leaning towards a possible leaking exhaust manifold , i had a k1500 jimmy once with a 350 in it and thought the motor had let go one time. Turned out to be the exhaust manifold gasket blew out on the middle flange. Just a thought.
elopez2
01-11-2005, 05:50 PM
U know what, I check for any leaks on the exhaust and didn't find anything. Took the truck to the mechanic and told me that it sounds like underneath the valve cover. Does anybody know of a problem like mine???????
busta
01-11-2005, 06:25 PM
well a little off topic but my brother said he had a similar noise he used ROYAL PURPLE OIL and it went away! also my in the mornig start up knock went away too once i started using that stuff also? so worth a try good luck
BOTTLEFEDCUTLASS
01-12-2005, 10:56 AM
Well to tell you all just about everyone I know that has the big Bow Tie has "THE TICK" The good news is it goes away 30 seconds after start. What causes that is not enough oil getting to the lifters fast enough.
internic
01-12-2005, 07:15 PM
i know this doesnt directly answer anyones question, but i have a 99 4.8 and it makes a clacking/ticking at off-idle due to collapsed lifters. its more noticeable on the right side, and it sounds like its coming from below the valve covers, which makes sense, cause thats where the lifters are. most lifters make ticking at below 2000 when they are collapsed but perhaps yours are broken in a different way?
jrn5898
01-14-2005, 05:20 PM
Take a vaccum hose and put one peace to your ear and the other to the exhaust as it is runnig and you can tell if you have a leak
norwood
01-15-2005, 07:49 PM
almost4, what kind of oil filter do you run? If it's a Fram, get rid it. I first heard of Fram filters contributing to an engine tick noise a short while ago. And being a lifelong Fram user, I thought this was B.S. I thought I'd test this theory out and tried an AC Delco oil filter and guess what? The ticking noise that my '99 Silverado had is gone. No more Fram for me.
elopez2
01-20-2005, 12:51 PM
Guys I change out the rocker arms on my truck 2001 silverado 4.8 engine. I took it to the mechanic and open the valve cover and told me that my rocker arms where bad, replaced them and I'm still getting this problem. I really don't known what it is but I get "The Tick" at 2,000 RPM's. I also heard that piston slap goes away after warming truck. Pls Help!!!!!!!!!!!!
BOTTLEFEDCUTLASS
01-20-2005, 01:22 PM
I'm telling ya it the nature of the beast! It just like the clunk from the yolk on the rear drive shaft.
elopez2
08-19-2005, 06:46 PM
Guys I finaly fix my Noise the tiking noise I was listening to was the camshaft (factory defect). Took out the oil pan and cover, found out that one of the lobes on the drive side was chipping out, change out the camshaft and lifters truck is running like never before. Evry time U change out a Camshaft U need neve lifters.
Google
Web AF
