engine specs?
AmatureCDV Driver
09-28-2004, 02:40 PM
alright, so i have the 1974 buick 350 engine that i am doing a rebuild on, but i cant find the specs on it so i know what things need to be adjusted or machined when i rebuild it. i have been searching the internet and cant find it. if anyone knows where to get the specs from it would be greatly appreciated.
Madcat455
09-28-2004, 04:00 PM
Blue printing specs taken from Poston's catalog for Buick 350's:
Timing (total): 34 deg.
Plug Gap .0035
Main Bearing .002
Rod Bearings .0015-.0002
Cam Bearings .001-.002
Piston to Valve .080 (Intake)
Piston to valve .100 (Exhaust)
Valve to Guide .0015-.002
Lifter to Guide .0008-.0015
Pin to Piston .001
Rod end play .006-.010
Rockers Not adjustable (without adjustable push rods)
Minimum deck clearance .030 (with .020 gasket)
Cam to cover .002-.004
Retainer to Guide .060
Oil pump gear .003-.006
Hydraulic Lifter Pre-Load .045
Will try to find the bore & stroke for Ya. (I think it was 3.75 & 3.75)
Ok... Bore is 3.8 and stroke is 3.85...
Hope this helps
Plug Gap .0035
Main Bearing .002
Pin to Piston .001
Hope this helps
AmatureCDV Driver
09-28-2004, 10:30 PM
thanks, that helps a lot
AmatureCDV Driver
10-03-2004, 09:34 PM
the info was really good. do you know where i can find things like
cam lobe
push rods length/diam
valves
stems
rods
pins\valve
rocker
cylinder
crank
bearing
i need specs on all of them, and because the engine is so old, i cant find info for it on the internet. any suggetions or help is greatly appreciated.
cam lobe
valves
stems
rods
pins\valve
rocker
cylinder
crank
bearing
Madcat455
10-03-2004, 11:45 PM
Try here.... Http://www.v8buick.com
Everything you wanted to know, just ask. I personally cant answer, but there are those on that site that can.
Good luck
Good luck
