Voltmeter fluctuating?mrtv99 09-27-2004, 06:12 PM Just wandering...I have a Jeep Grand Cherokee 5.2L V8 1993 and when it is put in drive the voltmeter drops toward 9 but never goes in the red. 1. I had the alternator checked and it was pushing everything it needed to. 2. I replaced the battery and still have the problem. Thanks for your help... dksob81 09-27-2004, 08:08 PM I would say that was a problem it should never be down that low I got the same jeep, and i am always at 14, give or take a half tach. Cam7 09-28-2004, 04:27 AM Run a DVOM across the battery terminals when running and compare to the dash guage. guages are not always accurate . If you dont have DVOM you can use a analog voltmeter. It should be above 13 volts when running. mrtv99 09-28-2004, 10:16 AM it gives me constant voltage whereas the one inside the jeep fluctuates, so I am assuming I have a bad gauge...? Cam7 09-29-2004, 04:49 AM I would say bad guage. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
