valve rattle
Google
Web AF
travisbconley
09-27-2004, 02:03 PM
I have a 2001 tahoe with the 5.3 liter. I notice when my wife cranks it up in the morning the first 5 to 10 seconds there is a noticable valve rattle. Anyone else experiencing this? Any advise?
TGARST
09-27-2004, 07:15 PM
mine does it too, sometimes, changed to Mobil1 5-30 seemed to help :screwy:
Tim 2003 Yukon 42K
95silverado
09-28-2004, 02:02 PM
It's probably the piston slap problem. You should find lots of info on here about it, just do a search in any of the chevy truck forums.
travisbconley
09-28-2004, 02:41 PM
I don't think it is pistno slap. It seems to be a tick from the top end. It sounds like a rocker or lifter. Also, it only lasts a couple of seconds.
glenncof
09-29-2004, 01:02 PM
I notice that also on different truck. It sounds like lifters are oil starved. When I first start after oil change it lasts much longer until oil pressure builds.
Oil filter should have anti-drain back. Some racing filters may not have this.
aero246
10-06-2004, 08:08 AM
The ticking is your lifters. The lifter are hydraulic and tick until they are pumped up full of oil, then no more click. You notice it longer when you change the oil b/c you have to have oil pressure to fill your lifter. The engine gets pressure first, then your lifters.
Hope this helps.
ryderjames
11-11-2004, 12:24 AM
It's your piston moving from side to side in the cylinder, ask your local service manager at any chevy store they will tell you its normal. It feels reel good when you throw down 40k for a tahoe and realize that it knocks after about 9000 miles, even using synthetic oil. Mine has to warm up about 15 minutes before I will even pull it out of gear and sometimes it still knocks
Google
Web AF
