Rear speaker wiring in 96 Jetta GLSJonesy GLS 09-23-2004, 09:01 PM Just bought a 96 GLS...taking out the stock speakers and dropping in 5 1/2 inch Eclpise with external crossovers....Could someone please let me know what the deal is with four wires entering the stock speakers???Every other car that i have had, only has had two?? Am I retarded or is this alittle confusing??Thanks for your help guys miro1118 09-24-2004, 09:24 AM two wires are going to the tweeters on the rear deck. I just ignored those. Jonesy GLS 09-26-2004, 12:09 PM thanks for the help Miro...I checked the wires and two are hot two are cold...The hot wires are together? Does this make sense? miro1118 09-27-2004, 10:35 AM There are two plugs that connect to the factory speaker. You can follow one lead up to the top of the deck where the tweeter is. Leave this plug off. I hope that helps. Two wires on the same plug are hot. How are you testing them? Jonesy GLS 10-01-2004, 01:47 AM miro, Thanks for the help....got it all figured out now.....since we're on the stereo subject, i was thinking about mounting a amp just inside the trunk on the side walls....any other places that may work better? miro1118 10-01-2004, 09:30 AM I dont have experience with amps, but, you might be able to mount it under the rear deck. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
