View Full Version : Fuel Economy
Fuel Economy
bestoil
09-22-2004, 10:50 PM
have 01 HD2500 anybody have any ideas on getting better MPG. All thoughts are welcome. And crazy ideas :2cents:
Franko914
09-26-2004, 12:30 AM
Assuming you will be doing mostly highway driving and not towing:
1. Replace water pump-mounted cooling fan with electric fan setup
2. Install high-flow air filter and tuned exhaust setup
3. Replace belt driven accessory pulleys with larger diameter ones
4. Replace tires with larger diameter, higher pressure, less aggressive treads (readjust speedometer/speed sensor)
5. Remove cat from exhaust/remove dog from exhaust
6. Remove exterior accessories such as roof racks, rear air spoilers, window weather guards, coon tails, etc.
7. Install full length running boards
8. Remove lead from foot
9. Install hydraulic regenerative braking system (currently under testing by US military)
10. Raise jib when tailwind picks up
J-Ri
03-01-2005, 12:11 AM
Assuming you will be doing mostly highway driving and not towing...
Assuming that, buy a car :screwy:
automotivebreath
10-01-2005, 12:31 PM
In attempt to improve my fuel mileage, I'm modifying my Suburban with grooved cylinder heads; the idea was developed by an inventor named Somender Singh from India. The modification requires raising the compression and cutting grooves in the squish area of the cylinder head. I picked up my heads from the machine shop today and will begin cutting grooves. Pictures and details of the project will be posted at:
http://somender-singh.com/content/view/34/37/
I have seen drastic improvements with the same modification in performance and race vehicles. Somender claims the same improvements in India. I'm hopeping for the best. With gas prices rising by the day we will need to find solutions fast.
automotivebreath
10-02-2005, 08:45 PM
In my previous post I attached a link to a site with the details of my Suburban but as you know the site is down. Hopefully it's temporary. Here's a picture of heads I grooved for a LT1 Camaro.
http://members.cox.net/raunch/LT1%20Shon%202
iburnh2o
11-28-2005, 03:16 PM
Here's another link to a new Somender head mod article.
http://fueleconomytips.com/content/view/73/33/
mastermason
05-16-2006, 12:59 PM
I have stumbled across a product that US Government, Military, China and Etc. have been using for the past 10 years and now the product has its patent which allows people such as myself and you to get our hands on it as DISTRIBUTORS! I myself have been using it for about 2 weeks. I have a 1999 Z71 Silverado 1500 it was getting 15-16 MPG and Now it is getting 21-23 MPG. My Wife has a 2001 Expedition 4wd it was getting 12-13 MPG and now it is getting 18-19 MPG. You can even use it in your crankcase (OIL) You use 1OZ oer quart in your crankcase (OIL) and 1OZ per 10 gallons in your fuel. So in my truck I use 2 1/2 )OZ and a splash cause I have a 26 Gallon Tank. I was the worlds best scrroge against products that had this great a claim, but I tried it and It simply works. The 4E Corp is shipping 50 containers a month to china (80 55Gal drums per container) and as we all know China don't buy squat from ANYONE THEY MAKE IT. But they are buying this product.
For more information on this product ot to become a distributor(which requires no inventory) or to just use the product or possibly to get a sample to try, go to
*Link Removed By Moderator*
If there are still questions that you can't find the answer to I will gladly except all phone calls on serious inquiry.
*# Removed By Moderator*
On the site you can find videos from FOX News and others who do a live study and test plus et emission test all live so you can see for yourself.
Plus the site has other charts such as savings charts, diesel charts, letters of recommendation (which the first one in the list is recommended by The United States Department Of Justice) plus many many more useful information.
Thank you for your time and I sinserely hope this post helps ALL of you in here looking for better fuel economy, money or both.
Thanks Again
Greatly Satisfied Customer
Kevin Harrington
Trenton Tennessee
Neutrino
05-19-2006, 11:41 AM
Unauthorised advertising is not allowed in AF, if you would like to do so feel free to contact the site administrators.
jonbyrd
06-23-2008, 08:20 PM
Hello frnds,
tjese techniques might come in handy.Have a look at it.
The inflation in gas prices shows no sign of slowing down and people are getting plenty worried about spending more and more of their income at the gas pump. Those who can afford it have switched to hybrids (http://www.amazines.com/article_detail.cfm?articleid=509180#), or have switched to smaller, lighter vehicles. Some institutions are looking for alternative sources of energy and the rest have resorted to gas engine (http://www.amazines.com/article_detail.cfm?articleid=509180#) fuel savers and various gas mileage increasing devices. However, I just need to point out that you can already do a lot to increase your gas mileage merely by improving your attitude on the road. One of the driving habits that hurt your fuel mileage (http://www.amazines.com/article_detail.cfm?articleid=509180#) is erratic driving. If you are constantly accelerating or decelerating, you tend to use up more gas than if you are cruising at a constant speed. The way the engine works is that it needs to use more gas to jumpstart the engine if the gears are shifted. Try to maintain a consistent speed and also try to keep your shifts in speed smooth. Gas mileage won't benefit from jackrabbit starts.
Another way you can conserve gas is by slowing down your overall speed if the situation permits it. Of course, you need to speed things up if you're on the highway, since slowing down is actually against traffic rules in that situation, but if you're on the freeway, you can safely get away with driving below the max speed limit. Just remember to keep to the right when slowing down, so you won't impede the people who are wasting gas.
Check your manufacturer for the recommended tire pressure and maintain the recommended psi. Bear in mind that the average tire (http://www.amazines.com/article_detail.cfm?articleid=509180#) loses about 1 psi per month. The reason for this is that under-inflated tires will have more resistance and will keep your car from moving as fast as it could. When a car struggles to move, it tends to use up more gas.
You should also cut down on the bling, or to be more specific, avoid souping up your car (http://www.amazines.com/article_detail.cfm?articleid=509180#) to the point that you have wider tires installed. These fancy plates and mags may look cool and some will even improve handling, but they tend to create more rolling resistance than stock tires. The more resistance it has, the more fuel your car needs. Saving up on gas by avoiding fancy tires acts in two ways; first, it saves money on long-term gas consumption, and as a bonus, also saves on the money you would have used to buy a fancy tire.
At the end of the day, if you really want to save on gas, avoid driving as much as you can. If you're going somewhere that is only a few blocks away, try walking or bicycling. This has an additional health benefit, since the workout (http://www.amazines.com/article_detail.cfm?articleid=509180#) you will get from the physical activity may actually improve your fitness. Instead of going to a drive through fast food, park your car and eat inside. Ideally, spend the evening at home and enjoy a home-cooked meal. You don't really need to use your something unless it is necessary, particularly if it's a gas-guzzling car.
jonbyrd
07-20-2008, 12:12 PM
Auto manufacturers around the world have faced financial trauma during recent years, resulting from consumer change in regards to both politics and the environment.
With no imminent resolution to the oil crisis in the Middle East, the price of crude oil has raised well over one hundred dollars, and will only continue to rise. Gas prices are now reaching above four dollars per gallon, and consumers around the world are looking for ways to save money on gas, as well as reduce their impact on the environment around them in this era of speculation about global warming.
There are quite a few ways that drivers are able to conserve gas while driving their current vehicles. The most obvious option is to cut down on the number of hours spent driving the car. Of course, this isn't a viable option for most people, especially in rural areas, but walking or riding a bike is a great way to save money and stay healthy.
Other conscious decisions including having your vehicle coast down hills, and avoiding stopping and starting. Driving on a busy street during rush hour is a great way to guarantee your car is burning gas.
As consumers are changing their driving habits, they have shied way from SUVs and other large gas-guzzling vehicles. With the decision to move away from trucks, vans, and SUVs, the automobile manufacturers around the world have introduced a variety of alternatives.
Hybrid cars minimize the consumption of gasoline by using an electric motor when possible. These hybrids greatly improve the efficiency of energy used by the car. Despite general belief, hybrid cars are easy to refuel and provide all of the typical function of our current gas-fueled cars, but with far less impact on the environment and driver's wallet.
Interested in how hybrid cars make the most out of every gallon? Hybrid cars shut off the gasoline engine when possible, and recover energy when the vehicle when brake. In addition, their sleek aerodynamic design and light materials allow them to further cut down the burning up of gas.
While hybrid cars are allowing consumers to make an impact now, the future of cars is decidedly based on hydrogen cars. Hydrogen cars are the holy grail of transportation. Just like hybrid cars, hydrogen cars use minimal energy consumption and will eventually have impact on the environment.
Research for hydrogen cars has been funding both by the government and private investors. For the time being, functioning models are demonstration-only as the cars are still expensive to build and operate.
Unfortunately there are still many drawbacks with hydrogen vehicles. Only a couple hundred are currently in use in the United States, due to their high costs. Because hydrogen vehicles have yet to hit the mainstream population, mechanical assistance is inconvenient. In addition, hydrogen cars create more exhaust than gasoline-powered.
Once hydrogen cars become more prominent in the United States, there will be need for many more hydrogen stations used to fuel cars. It has been approximated that the cost will be around $500,000,000,000 (five-hundred billion dollars) to replace the nation's current gasoline-based infrastructure. However, because of the global gas and oil crisis, the investment is still considered a necessary one.
Before consumers know it, energy-efficient cars will become the norm on the market, not the exception. Hybrid cars are no longer taboo, and we can anticipate hydrogen cars to follow sooner than we think. While the prices of oil and gasoline may improve, expect to find financial relief with these new innovations.
More info at:
<a href="http://www.waterfuelkit.net">free tips on alternative for fuel</a>
J-Ri
07-20-2008, 05:58 PM
Coasting down hills uses more gas (unless coasting to a stop light). For maximum fuel efficiency, coast going up hills (still giving it some throttle, but a bit less than on level ground), and accelerate gradually going down hills. I drove a vehicle that shows instant and average MPG, and driving the way I just said makes a HUGE difference vs. maintaining a steady speed. I'm not sure if the MPG the vehicle showed was 100% accurate, but higher numbers are higher numbers. Assuming it was 100% accurate, I averaged 28 MPG in a 2002 Camry. My mom (who loaned me the car while I was looking for a new one), in very similar driving averaged 18 MPG. Turning the A/C on and rolling up the windows also helps, and it helps a lot if you turn the A/C off while you are coasting up the hills.
I assume you meant hydrogen vehicles produce less exhaust that gasoline powered vehicles? Regardless of the total amount of "exhaust", if the exhaust is water, we don't care how much it puts out!
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
