How to make your own kit?
Google
Web AF
Goosse
02-12-2002, 03:13 PM
Is it even possible to make your own body kit? I'm having an idea for a wing but I don't know how to start (if it's even possible). Any suggestions?
Goosse
02-12-2002, 03:14 PM
Exept for, just buy one:D
slociv
02-12-2002, 03:19 PM
this guy made his own kit....:rolleyes:
www.geocities.com/cuzinyung/neatcars/getto1.jpg
Goosse
02-12-2002, 03:23 PM
Not what I was planning to do. I need to know what material to use to make the mold, what material is best for the wing, stuff like that.
supafly1024
02-12-2002, 03:31 PM
If you're really wanting to try this then you'll probably want to use fiberglass.
Goosse
02-12-2002, 03:33 PM
anyone got any links or so?
xivera
02-12-2002, 04:25 PM
Learn to work w/ fiberglass. Once, you know how to deal with that then you can move on to composites (carbon fiber/kevlar/etc.). It almost the same thing.
Do a search on www.google.com. There's tons of fiberglass stuff/places...
www.selectproducts.com has videos on fiberglass work but, in car audio/interior applications but, the techniques still apply...
Urethane is another choice of material but, is totally different. You inject the material into a mold. You need machines for this... I think.
Goosse
02-12-2002, 04:28 PM
Thanks
jeisai
02-12-2002, 04:34 PM
Yeah my mom's friend (who's extremely rich and has his own private shop) made his own ground effects for some old mustang of his. Doesn't sound like it'd be too fun though.
90CRXZCSi
02-12-2002, 04:36 PM
That's the uglisest thing ive ever seen. What was he trying to get at? :confused: :rolleyes:
OisinT
02-12-2002, 04:40 PM
hey dont knock on my bodykit bish! :mad:
xivera
02-12-2002, 04:46 PM
Thanks
http://www.3dpcgame.com/cwm/s/otn/happy/smileJap.gif
bluecoma
02-12-2002, 05:28 PM
Get a big piece sheet of styrofoam sand it down using 80 grit sand paper to the mold you would like. Cover it with compund glue and aluminum foil, then cover it with fiberglass resin. That's all i remember, i'll post the site where i got the information from as soon as i find it again. The end product came out freaking awesome.
bluecoma
02-12-2002, 05:45 PM
Custom Body Kit (http://www.geocities.com/silverkit98/BodyKit1.html)
Here is the site.
And here is the kit;
http://www.geocities.com/silverkit98/AccentFront.jpg
http://www.geocities.com/silverkit98/winter2.jpg
If the pics don't work they have some on the site above
xivera
02-12-2002, 09:13 PM
I 'd like to mention... Don't let that resin touch the styrofoam! It will burn a hole right through it. And, do use gloves. ;)
Goosse
02-13-2002, 02:24 AM
Originally posted by bluecoma
[B]Custom Body Kit (http://www.geocities.com/silverkit98/BodyKit1.html)
Here is the site.
Thanks for the link. This was what I was looking for. Since I worked a lot with styrofoam before I could give it a try. I was also considering using Balsa would as the center and cover this with the fiberglass resin. Would this also work?
Paucey
01-15-2004, 01:22 AM
I feel bad bumping such an old post, but this is one of the only sites I've found on the net that mentions any techniques on making custom body kits.
I want to make my own custom body kit, but I've run into some problems. First of all, I'm debating what material I should try to make it out of. My first choice was fibreglass, but I'm afraid now that it might be too brittle. My second choice was then Ployurethane. I thought that if I could carve a model from polystyrene, I could then create a mold from that, and then cast a polyurethane finished product. This all seemed well and good, but I thought of a new problem. If I were to design a skirt for the left side of my car, how could I mirror it to have an identical skirt on the right side of the car? Also, how could I mirror the left half of my bumper's design to be symmetrical with the right side of it? A haphazard array of molding and inverting molds, and then molding again and again would hopefully end up with such desired products, but the chances of such things succeeding are quite slim.
So I figure there must be some better way to design and produce a body kit. Other people obviously do, but I cannot for the life of me think of any viable process to produce mirrored symmetrical products. I was thinking of perhaps using a Rapid-Prototyping Machine... but then I'd need to get the right dimensions on the computer to create a finished design, and I don't have the money to spend on blind trial-and-error for that.
Does anyone have any ideas or suggestions?
tibby01
01-15-2004, 02:12 AM
hey atleast your using the search feature...good job.
1st. fiberglass is not brittle...at all. 7 layers, and you could easily use it to prop up a car.
head over to ebay.
http://search.ebay.com/search/search.dll?MfcISAPICommand=GetResult&SortProperty=MetaEndSort&ht=1&query=fiberglass+mat
then to a local marina or something for resin and hardener.
kjj
01-23-2004, 09:05 PM
that sounds really cool i to a little read at the web site that was posted and i am interested in tring it out but im still having a hard time in undertanding what they mean by putting it and the wet sand papper part and how do you atacht it to the bummper ....can some one plz help me out here....thanks
lkailburn
01-24-2004, 12:07 AM
go to www.termpro.com or www.carsound.com and go to the fabrication section of both. there are a few threads floating around in there. currently i'm working on custom front and rear lips for my 97 civic.
rc420
10-31-2005, 05:02 PM
you can try cutting your kit in half and welding an extension then covering it in fiber glass like here...http://www.cardomain.com/member_pages/show_image.pl?bg=FFFFFF&image=http://memimage.cardomain.net/member_images/3/web/651000-651999/651278_21_full.jpg
it works and is the easiest way.
Google
Web AF
