just bought 90 chevy truck...
Google
Web AF
Muskrat2004
09-21-2004, 11:13 PM
OK, I just bought a 1990 2WD chevy with a 350. I'm new to V8s, so with about $1000 extra to spend, what can i do to the engine to make it more powerful and sound awesome? cam? headers??? This 'newbie' does appreciate any help.
BleedDodge
09-26-2004, 12:03 AM
These are good trucks. They'll rust out and eat transmissions but I don't think you can kill them.
Cam and headers/exhaust is exactly where I would start with a grand to spend.
MrPbody
10-01-2004, 01:43 PM
If that's a throttle-body injected engine, Edelbrock makes a Performer intake. Comp Dual Energy or Xtreme Energy cam would be the best choice. Something in the 212/220 @ .050, .445" lift range. A good set (not cheapies) headers will make the most improvement.
macktoschool
10-06-2004, 08:07 AM
Sounds like you're getting great advice. I wouldn't forget to do a compression check before pumping up the motor though. A marginal set of Rings will go South in a hurry once you start packing the cylinders. That's why I always suggest starting with the exhaust and working your way up. Good luck, sounds like it will be a nice truck.
sub006
03-01-2005, 11:33 PM
K&N filter element in your stock housing, Edelbrock header and Y-pipe system going into a hollowed-out stock or new high-flow cat, 3" single pipe to a Gibson muffler and on back from there.
If you get ceramic or titanium coating on the exhaust, underhood temp will go down enough for one of K&N's intake kits to work at its best.
Before adding a cam or any internal parts/work, make sure your rings, valves, etc. are up to snuff. You didn't say how many miles on the truck, but many times a basic overhaul produces more performace than hanging performance parts on a tired engine. Once you're sure the motor is tight, you can add the goodies to a solid foundation.
PS stay away from Vortec heads, lots of field reports of cracking under high performance demands. Put your money into aftermarket heads, preferably aluminum.
Google
Web AF
