Is Dextron 3/Mercon an acceptable tranny fluid?
95j30dude
09-21-2004, 08:07 PM
I am attempting to do a tranny service. I went to part store and asked for a tranny fluid for my J30, and he said Dextron 3/Mercon will work.
Is he right? Any hint on tranny service DIY?
infinman
09-23-2004, 03:48 PM
Dexron 3 is good to use.It states which fluid to use on your trans dipstick.Do not remove the trans oil pan as Infiniti does not use a filter.They only use a screen for oil pick-up.removing the pan is a waste of time.Draining the oil pan removes only approx.1/3 of total trans fluid.To completely remove all fluid it has to be done by a trans flush machine.By just draining and refilling the oil pan doesn't do much.
Good luck
Speedy_1234
10-01-2004, 02:03 PM
Ok but where can I get that job done in my 94 j30 and where can i find that machine plus I found out when I took out the tran-pan About a gallon came out also it has like a filter it has 3 screws but if i wrong to tell me
