im haveing fuel problems
Google
Web AF
whatcha/got/racer
09-20-2004, 11:37 PM
just got the car running the timeing was off and now it idles for alittle then dies and if i rev it it stops quicker wondering what fuel stuff i need to look for fuel pump carbs let me know thanks
adam9090
10-11-2004, 03:59 PM
Tune the carb/s and sync them if you have two and make sure there is oil in the dash pot
whatcha/got/racer
10-15-2004, 01:14 PM
yeah i was thinking of that, thanks alot. i spoke to a local shop said the same.
Great-King-Rat
10-27-2004, 08:21 PM
If this doesnt work you may want to consider a carb rebuild. I had the same problem right after getting my '73 running and thats what I had to do. Good luck.
whatcha/got/racer
11-09-2004, 11:35 PM
how hard would a rebuild be on the su carbs and know anyone with a good kit. thanks.
CraigFL
11-10-2004, 07:50 AM
Try here:
http://www.propermg.com
http://www.victoriabritish.com
http://www.lbcarco.com
http://www.mossmotors.com
whatcha/got/racer
11-10-2004, 01:32 PM
thank you for the info i like moss motors i ordered there catalog few months back i was wondering if anyone was cheaper.
CraigFL
11-10-2004, 03:08 PM
Go here to get 10% off of Moss....
http://www.oregontrail.net/~roopsmg/newparts.htm
garync1
12-01-2004, 06:51 PM
Put a weber on the 73 I had .ran alot better. Got tired of working with the old twin carb set up.Ran a little faster too.
stevecon
12-04-2004, 11:55 AM
Sometimes the water choke fails making adjusting the carb a real pain in the neck! I put a manual choke on mine to stop the insanity. The car may have eaten the rubber diaphragm on the top of the carb. Tining that Stromberg Carb can be a beast.
76 MGB
whatcha/got/racer
12-06-2004, 01:48 PM
i have dual su carbs and the fuel i think is the problem. it has an amber color and some people have said that gas in tank is bad bit i drained it already and the problem of the gas has continued wondering what a solution could be.
stevecon
12-08-2004, 08:32 PM
O.K. My wife just bought a 74 midget, with a gas tank full of lacquer. Lots of gum. Fuel pump was toast, float bowls on Carbs were full of gum too. I actually used compressed air to blow the fuel lines free to finally get gas to the carbs. (O.K. I lied my fuel line runs to a gas can right now. ) No, it is not a driver yet. This Spring..ha.ha.
If you havent swapped out the fuel filter, try that. I'm not sure on the MGB gas tank but the Midget tank '74 had a screen over the fuel pick up area that was gummy yours might be too. There are some products out there that will clean the tank. I just did a 67 Austin Sprite tank for a friend. Clean - Etch - Seal. Tank will last a long time now.
I hope this helps.
KimMG
12-10-2004, 04:49 AM
Amber colored gas could mean your tank is rusting on the inside. Your fuel filter may need replacing. Check the fuel bowls in the carbs, make sure there is no debri clogging anything. Sea Foam is a fuel system cleaner and a fuel stabilizer, available at marine supply stores.
Flash75
12-12-2004, 06:06 AM
When the engine stops can you hear the fuel pump running? If it is not clicking and is an SU pump try hittinh the pump with a screwdriver handle to see if it starts. If it does the fuel pump needs points replaced or adjusted. If you can hear it clicking, remove the fuel line with ignition off. Find a quart size container and turn on the ignition to see how much fuel pumps in appriximately 30 secomds. It should pump about a pint in 30 seconds. If fuel delivery is ok you may have carburetor problems, probebly float needle valves are sticking in the closed position. I assume you have SU HIF4 carbs, you can hook a short peice of hose to the carb fuel inlet and blow into the hose, lift the piston and note if fuel runs out of the jets. If no fuel comes out of the jets you need to look inside the float chambers, for the HIF carb you have to remove the carbs to check the float chambers. If you find Grose Jet float valves in the carbs I suggest replacing them with the correct SU float valves. You can replace the float valves without rebuilding the carbs, there is an o-ring for the float chamber cover that can be reused. Get your fuel delivery correct before deciding if the carbs need rebuilding.
Clifton
whatcha/got/racer
12-14-2004, 11:09 PM
thank you for that info. i cleaned the carbs awhile ago. im going to try the fuel flow. the fuel flows constanly i can hear the pump when it does die. i will try your test though. thanks again
KimMG
12-15-2004, 01:20 AM
If the rubber hoses going to the fuel are cracked, the fuel pump will make noise and pump air not gas. Have you measured fuel delivery at the carbs.
whatcha/got/racer
12-18-2004, 03:54 AM
havent meaaured but this weekend im going to go throught the whole system and inspect whats goin all the info helps
andi_byz
12-23-2004, 11:45 PM
How Did Your Flow Test Go ?
whatcha/got/racer
01-10-2005, 08:31 PM
found the prob the gas tank was thrashed and that caused the pump to mess up so im replaceing both.
whatcha/got/racer
04-22-2005, 11:54 AM
its been a few months sense ive worked on the car. the fuel pump was gone so needs replacing. i took te fuel tank out and the fuel pump. i have a holley fuel pump wondering if it would flow to much or will it work. i need a new gas tank as well i was given the fuel pump and a friend gave me a 16 gallon fuel cell its a little big but thats ok for now wondering if you guys have suggestion on whether to get a new gas tank or get a smaller fuel cell wondering if i can still mount under the trunk. i want to make this a driver and do some auto crossing.
CraigFL
04-25-2005, 07:57 AM
As far as the fuel pump.... Two important things:
1. What does the pump do at zero flow -- does it stop pumping like the SU? If it keeps pumping you may need a return line.
2. Max pressure should be 2.5-4psi. If not, you will need a regulator.
KimMG
04-29-2005, 02:41 AM
If you want to use the car for racing, check the rules for your class regarding fuel tanks.
whatcha/got/racer
05-02-2005, 11:11 AM
my weeks freed up alittle so ill see about the pump if it stop or not. thanks for the info.
Google
Web AF
