VTEC switchhh65acivic 09-20-2004, 07:06 PM Is it possible or worth it to hook the vtec up to a switch so you can turn it on or off instead of it being determined by the RPM? Beastiek2 09-20-2004, 07:11 PM VFACII Apexi makes it 335$ You cant turn Vtec off, you can just adjust it. BTW why would you want a switch for it? TrickyTrickyEngine 09-20-2004, 07:34 PM What the guy said above producepeteSi 09-20-2004, 08:55 PM Just don't mess with it. Honda took the time to find the right RPM engage point. Unless you race your car on a track, I wouldn't do anything to your VTEC. Don't try to turn VTEC off. ??? 97CivicX 09-20-2004, 09:52 PM you could make a switch for it, splice the signal cable between ecu+solenoid and put a switch in as stated: why? stook02780 09-21-2004, 09:38 AM you could make a switch for it, splice the signal cable between ecu+solenoid and put a switch in as stated: why? I just read this same question on another forum. The person wanted it to act like "NOS"... Enuff said toozious 09-21-2004, 11:23 AM I just read this same question on another forum. The person wanted it to act like "NOS"... Enuff said That's gotta be the funniest post I've read today. Beastiek2 09-21-2004, 11:26 AM wow Miataracer 09-21-2004, 01:03 PM high speed sustained cruising without using as much gas? lol Alejo_nin 09-21-2004, 04:44 PM Hmm, VTEC-NOS not such a bad a bad idea....(did you notice the sarcasm?) hh65acivic 09-21-2004, 05:46 PM I dont want it to act like nos. I was thinking that if it was on a switch you could turn it on to let more fuel in the mix even at low rpms. whatever vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
