a/c control panelcowboy36618 09-19-2004, 10:56 PM i was working on a ignition problem i had which turned out to be the icm goen bad, i then drove the car for a test drive and noticed the a/c control panel wasnt working. I have checked all the fuses i could find, the control panel for the a/c still dont work. when this happend i was checking for codes and i had unplugged the wrong wires and put the jumper on the wrong wires and it sparked , the wires i had touched was the brown plug that has two wires goin in and out of itone side is hot and one side aint, when that happend i think i blown soemthing or did something but i dont know what i did, but now the control pannel for the a/c is not working, the a/c blows cold and works ,just on the last setting it was on before i did whatever i did, if someon e out htere can help me figure out what it waws i did or touched or blew I would appreciate it very much, ive looked and done what i thought to do but cant find any fuses or whatsoever blown or unplugged to cause this a/c control panel not to work, it just dont have any lights that come on when you turn the key on or it running , and theres no control over it as far as to turn it from vent to defrost. please help e out if you can, thank you vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
