Wheels Woobling
dat1laosguy
09-17-2004, 10:04 AM
Can anyone help me? I have an on going problem with my rear driver side wheel woobling I had my rims check at a local discount tire store and they said it was fine nothing wrong no bends or so... I had told one of my friend about it and he said my brakes locks up..or need new knuckles....dunno but anyways I have drums brake in the back
thanks for any help at all :2cents: :eek: :eek:
johnb16a2
09-17-2004, 10:07 AM
Probably the bearing/hub unit is bent. They are "easy" to replace but are expensive.
CivicSiRacer
09-17-2004, 04:49 PM
Are you sure your lugs are tight?
dat1laosguy
09-17-2004, 06:35 PM
ummm yea but thanks for checking cool guy
dat1laosguy
09-17-2004, 06:36 PM
and if it wasnt tight it would make a loud knocking noise and i would have notice that noise
DirtyD777
09-18-2004, 12:03 AM
My car did this afew years ago..like they said. Check your wheel bearings.
dat1laosguy
09-18-2004, 09:38 AM
hey thanks man ....did u do the labor yorself adwas it hard if u did?
DirtyD777
09-19-2004, 12:02 AM
no man it's really easy the only thing is I didn't have a socket big enough to fit it so I had to rent one from autozone but it wasn't expensive..Mine were just loose from when I put the axles back in after putting the engine in I didn't tighten them properly. Also there is that little tab that you bend inwards after they are tight.
eckoman_pdx
09-20-2004, 05:36 AM
Just a thought, I'm not saying it couldn't be DirtyD777 suggestion, but your wheel could be out of balance and need re-balancing.
