need alternator for 2.2?
Google
Web AF
Gilmore03
09-16-2004, 09:22 PM
well once again, i have another problem with my cav, its a 94 and teh ALternator just went. I started teh car up and let it sit for about 5 minutes, then disconnected the terminal to teh battery and it stalled. My question is if anyone knows where i can get a alternator for as cheap as possible??? Im not keeping teh car so...
godenm
09-16-2004, 09:40 PM
on computer controlled cars the car should shut down when bat. is disconnected
Classicrocjunkie
09-16-2004, 10:47 PM
pick n pull
Dasbogie
09-17-2004, 01:40 AM
I have an alternator from a 96 Cavy 2.2, If that would work it's yours for just the shipping cost. let me know
Spencer
Dasbogie@atlanticbb.net
mrrob
09-17-2004, 02:01 AM
Did you put a volt meter on the battery?, if it's putting out 12volts it's probably the alternator, If it read 14-14.5 it's charging, as far as a cheap fix goes, either go to your local wreckers or go to a rebuilder in you local area, most will repair (Replace Regulator), probably your problem fairly cheap.
Good Luck
Mr.Rob
booya42301
09-17-2004, 02:20 AM
I think i need an alternator also i dunno if it is the alternator tho... as i was pulling into work it made this sound... i never heard it before it got louder as a pressed on the gas...well after work i went to check it and it sounds like its either coming from the alternator or sumin under it. And when i shift to 5th gear now it acts like it wants to die ... i wanna get this fix since i get paid 2moro... can anyone help???
Gilmore03
09-17-2004, 03:29 PM
i do have a volt meter but i dont know how to use it!! lol yea i know pethetic, but its got liek 20 diffrent things i can put on, i dont know what mode thingy i put it on
Google
Web AF
