questions on suspension
matt11583
09-16-2004, 04:44 PM
i have worked on a lot of engines in the last few years but i have never really got under the car to do much suspension work??? how exactly does it all connect and what parts do wat for the car? if i was moddin a car wat should i change first in suspension?? does anyone kno of a site where it explains the details of how suspension works? thx
Alastor187
09-17-2004, 01:12 PM
Check this out:
Suspension
http://autozine.kyul.net/technical_school/suspension/tech_suspension1.htm
Handling
http://autozine.kyul.net/technical_school/handling/tech_handling_2.htm
There is no simple answer to how suspension works because it depends on a variety factors. But the Autozine links should help you to figure what the primary objectives of the suspension are for racing (I assumed this was your area of intrest).
If i was moddin a car wat should i change first in suspension??
If you read the links and understand the basics, you should able to decide for yourself what areas of the suspension are most important to your goals.
My biased opinion is that tires are the most important aspect of vehicle dynamics but that’s me.
Check this out:
Suspension
Handling
Rufe
09-17-2004, 11:15 PM
I think your biased opinion is biased towards the truth side,
(ie: good advice)
You might consider a wheel and tire package as opposed to just tires, though.
(ie: good advice)
