P0410 Secondary Air Injection System Malfunctionanusemoon 09-14-2004, 09:31 PM P0410 Secondary Air Injection System Malfunction what parts are defected in this code,,,,,,help anusemoon 09-14-2004, 09:31 PM P0410 Secondary Air Injection System Malfunction 2001 3.5 68k onehunglow 09-15-2004, 11:09 AM I had exactly the same problem - Check Engine Light came on and stayed on....it would sometimes go off but mainly stayed lit I had an independant check it who said it was in the 'secondary air injection ' Since I knew it would be expensive, I marched to the dealer and they changed the sensor - I don't have much more on this except the bill (it was under warranty so they didn't list the price just what they did) - do you need to know more? anusemoon 09-15-2004, 11:14 AM Yes Lots more,,, where is that sensor located...also any other components that might be damaged if its not the sensor,,,thanks for your help onehunglow 09-15-2004, 02:54 PM I am trying to locate the bill ....but I wanted to answer this part of it - it was a faulty sensor that was replaced - it wouldn't have caused damage to other components but it could affect the lean/rich mixture which could lead to performance issues and gas mileage. I had neither - it was just an annoying light to have on Apparently the dealer said that this was a common problem in the 2nd gens (>2001) When I find the bill, I can list the part and maybe the amount of hours they spent would be there which woudl give you an idea of the complexity Why woudln't you have this repaired under warranty? - it falls under the 5-year emission control warranty even if your other one hs passed anusemoon 09-16-2004, 10:16 AM its my bothers car i have a 96... im not sure is he has the warranty....he bought it used... i will ask him and see.... anusemoon 09-18-2004, 01:37 PM no warranty,,,,,, do you know what the sensor called and where it is located Destry 11-14-2004, 07:29 PM Did you get your problem resolved? I have similar problem that started when the gas cap was left open. Reset the code, it stays off till the next fill up, then after about 50 miles it come back on. Any help? apostolakisl 11-15-2004, 04:18 PM I had exactly the same problem - Check Engine Light came on and stayed on....it would sometimes go off but mainly stayed lit I had an independant check it who said it was in the 'secondary air injection ' Since I knew it would be expensive, I marched to the dealer and they changed the sensor - I don't have much more on this except the bill (it was under warranty so they didn't list the price just what they did) - do you need to know more? I have the same problem. I assumed it would not be covered under warranty and just reset the light. My reading has indicated the secondary injection system is a completely useless system, so I figured I would just reset the light when it comes on. . . about once per month. I have an 01 with 60,000 miles, you say this falls under a different warranty than the 36,000 mile 3 year warranty? Destry 11-17-2004, 05:50 AM Thanks Neta 08-24-2005, 11:20 AM I was driving with P0410 for 8 months, untill 6 weeks ago I desided to do the tune-up. My Aurora had 180K kilometers on it, so it was time to do something... It appeared that my Plugs were completely burned - down to the isolators. Mechanic also replaced PCV valve, cleaned the throttle body, did the fuel and air filter... He also scanned my Oxigen sensors - they were OK. After all, he told me that my P0410 will likely disappear pretty soon. Because of the poor plugs, engine had poor (incomplete) fuel burn, so my Oxigen sensor registered higher oxigen content and interprited it as the Secondary Air Intake vacuum loss - like it was sucking air into the collectors due to the leaking Sec. air intake valve(s). Indeed, in 3 days Check lignt went off. Then, in 5 days, it came back for few hours, and disappeared again. One month later I am still driving without Check (Keepping my fingers crossed!) irishpwr13 09-02-2008, 01:54 PM I had exactly the same problem - Check Engine Light came on and stayed on....it would sometimes go off but mainly stayed lit I had an independant check it who said it was in the 'secondary air injection ' Since I knew it would be expensive, I marched to the dealer and they changed the sensor - I don't have much more on this except the bill (it was under warranty so they didn't list the price just what they did) - do you need to know more? what is usually the problem when this secondary air injection system, is it expensive and how much BNaylor 09-02-2008, 02:30 PM what is usually the problem when this secondary air injection system, is it expensive and how much Welcome to AF. Sorry but please check the date of the last post in the thread. Since this is an old thread it has been closed. Just repost following our guidelines below. Old Thread Guidelines (http://www.automotiveforums.com/vbulletin/showthread.php?t=891499) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
