Page updated on 02-21-2018
Can a 00' firebird v6 hae straight pipes?
TransAm_Ownr
09-12-2004, 12:24 AM
Hey guys just wonderin' if i could purchase some straight pipes for my 2000 firebird 3800 3.8L V-6 engine?? Any suggestions??
86TATpi
09-12-2004, 02:46 PM
Are you doing this to eliminate the cat? Where to where are you going to straight it?
JoeJoe231455
09-12-2004, 06:44 PM
Yeah, it can. But it won't sound very good. It is a good idea to keep the cat on gm V6 for ricey sound supression.
Villain281H
09-20-2004, 10:40 AM
you can run it straight from the headers/manifolds back in single 3" pipe and over the axle to a muffler or not. I agree, cat probably not costing you much in power unless the car has a bunch of miles and needs replacing, and it'll sounds better with cat in place.
cndctrdj
09-21-2004, 09:49 AM
bmr sells a panhard bar that allows you to run true 3 inch duals now
GreaseDog
09-21-2004, 04:37 PM
got a clicky on that panhard bar?
cndctrdj
09-22-2004, 08:31 AM
http://www.bmrfabrication.com/F-bodySuspension.htm
check out the bottom of the page
TransAm_Ownr
09-22-2004, 12:30 PM
i dont understand
TransAm_Ownr
09-22-2004, 12:50 PM
where is this exhaust system at excatly????
cndctrdj
09-23-2004, 12:24 AM
if you look at the panhard bar on your car it is a straight piece that goes diagonal from one side to the other
your original 3inch pipe runs over it at one point
this new panhard bar has a flat spot in it where you can stuff 2 3inch pipes through it where the one 3inch pipe used to go
that was the one spot holding our cars back from being dual exhaust
TransAm_Ownr
09-23-2004, 12:31 PM
o i c...ok thanks i will look into that
cndctrdj
09-23-2004, 03:38 PM
anytime thats why i like these boards.
