Fuel Pump Relay
Google
Web AF
bowtie tim
02-09-2002, 11:33 PM
I have a 1995 S-Blazer, 4.3 Vortec, 4WD. Does anyone know where the fuel pump relay, or the fuel pump test lead is located???
Tireburner
02-11-2002, 09:45 AM
My locator says for Vin W or Z that the fuel pump relay is inside the glove box. (4.3L)
webcrawler
10-12-2002, 12:24 PM
Yes
The fuel pump relay is in the glove box
Open Glove Box
Remove relay cover. Becareful clips are made of plastic!
You will see 3 relays the exact size.
The fuel relay is the second one from the drivers side. I think. $20 or so.
Fuel pump relay should active for 2 seconds every time you turn the key on.
Let us know what happened
:bandit:
webcrawler
10-24-2002, 12:40 PM
Correction!!!
If your looking at the three relays from the passenger seat.
The fuel pump relay is the first one all the way to the left
Fuel pump relay should always activate for 2 seconds every time you turn the key on.
Check engine light should come on as well.
As well as a few other dash lights.
Check that every time before you start your car.
webcrawler
10-24-2002, 12:47 PM
Fuel Pump test lead is located on the drivers side firewall/fender.
Between the Brake Booster and the drivers fender
Look around that corner.
Its bunched up with the rest of the wires there so you have to give it a good look.
You'll see one wire all by itslef with a plastic connector on it.
If you apply 12V to this the fuel pump should come on.
Always handle wires with care
These wires have to do with the Engine Computer as well so be careful.
kscott9
09-12-2005, 09:45 PM
the test plug is under the hood, driver's side up by the brake canister. there is a harness and a red wire with a plug on it. Connect it to the battery positive side to test the FUEL PUMP.
The fuel pump relay is in the glove box.
Google
Web AF
