Please Help!! No brake lights or turn signals, RAM 1500
tanabil
09-06-2004, 05:06 PM
I have changed all the fuses that might apply, changed bulbs & checked the wiring... Why the turn signals & brake lights at the sametime? Is there a common denominator??? I would appreciate any help!!!
Thanks,
Bill
BleedDodge
09-06-2004, 10:01 PM
Did you check all the fuses and relays under the hood as well?
tanabil
09-07-2004, 06:49 AM
Yeah, I checked the larger fuses under the hood. I have not replaced any of the relays though. I called the dealer and he said it sounded like a wiring problem...but would that affect both rear brake lights & turn signals??? The tail lights & third brake light still work. Thanks for the reply, this is driving me nuts!
Bill
tanabil
09-10-2004, 12:57 PM
Well, I guess I will have to take it to the shop to get tested. I am beginning to think it is probably the turn signal switch. But that is just a guess. I appreciate the responce... :)
union4me
09-25-2004, 01:04 AM
It's your relay switch located in your fuse box on side panel of drivers side. I had same problem with my 3500 last year...it is no wiring problem.
