1995 OBDI or OBDII Confusion??? HELP!BlazerLT 09-05-2004, 04:16 PM Confusing? Oh hell yea...... Ok, now I heard about the OBD1.5 stuff but this takes the cake. Here is my cliff's notes for you: OBDII DLC under the dash OBDII Type Computer on Passenger wheel well in engine Compartment. Sticker on Fan shroud says OBDI certified. WTF! Which one is it and can I use OBDII software to view my sensor information? busa_4 09-05-2004, 08:26 PM becarefull as the gm obd1 connector looks alittle similar to the obd2 connector. you have a 1995 so it is obd1 compliant. if you definitley have an obd2 connector under the dash then you can use an obd2 scan tool to access the sensors variables. i had a 1994 toyota camry v6 with an obd2 connector. it wasnt obd2 compliant but you where still able to scan it with a obd2 tester. good luck! BlazerLT 09-05-2004, 09:10 PM Yes, it is the 16 pin DLC OBDII connector so I guess I will need a OBDII scanner. Thanks. busa_4 09-06-2004, 07:50 AM yes you will need an obd2 scanner. i picked up a generic obd2 scanner on ebay for 115.00. movin2stereo 09-06-2004, 09:23 AM 1996 and newer are OBDII.In your case I don't know. busa_4 09-06-2004, 11:44 AM some manufacturers put the obd2 connector on there vehicles before is was mandatory in 1996. BlazerLT 09-06-2004, 02:05 PM 1994 vehicles equipped with the early OBD II systems include Buick Regal 3800 V6, Corvette, Lexus ES3000, Toyota Camry (1MZ-FE 3.0L V6) and T100 pickup (3RZ-FE 2.7L four), Ford Thunderbird & Cougar 4.6L V8, and Mustang 3.8L V6. 1995 vehicles with OBDII include Chevy/GMC S, T-Series pickups, Blazer and Jimmy 4.3L V6, Ford Contour & Mercury Mystique 2.0L four & 2.6L V6, Chrysler Neon, Cirrus and Dodge Stratus, Eagle Talon 2.0L DOHC (nonturbo), and Nissan Maxima and 240 SX. Not all of these early applications are fully OBDII compliant, but do include the major diagnostic features of the current system. xpress60 09-26-2004, 02:29 PM I have the actron CP9145 scantool and it will read the 95 s-10 obd 1.5 codes. BlazerLT 09-26-2004, 04:02 PM So what I have learned is the OBDII in the 1995s are just a more simple version of the 1996 OBDII with less sensors. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
