2001 chevy tahoe stalling in low speeds???psanchez 09-01-2004, 11:10 AM I have been having stalling problems with my 2001 chevy tahoe LT. It has just got worst, before it would stall maybe once every three weeks, then it was once a week, now it just got worst it does it everyday, just this morning on the way to work it stalled three times. It only does it in low speeds, like this morning i was in traffic and when you let go of the gas pedal the truck shakes and turns off. The electrical stays on like the radio and lights, but when it stalls i do not get a message in the message center, the only thing that shows up is the battery light. after it stalls it starts back up right away, but today it did something weird, after it stalled the second time and i started it, my fuel showed low fuel it was on empty even though it had gas, then it stalled again, and it started back up and the gas gauge went back to normal. it also does it alot when i'm parking. very weird, i am so fraustrated with this truck, you would think a truck this new would do things like that. i have read other forums stating to change the crank shaft sensor????? i have already changed my fuel filter. please help. GMMerlin 09-01-2004, 12:33 PM if this problem only happens when your foot is off the gas pedal, I would recommend you clean the throttle body first. psanchez 09-01-2004, 12:51 PM if this problem only happens when your foot is off the gas pedal, I would recommend you clean the throttle body first. THANK YOU FOR RESPONDING, HOW DO YOU CLEAN THE THROTTLE BODY? GMMerlin 09-02-2004, 09:17 AM With the engine OFF Remove the duct from the air filter box to the throttle body...spray some choke cleaner into the throttle body and scrub the housing and blade with a soft tooth brush..spray again and wipe clean. There are some GM TSB's on this concern also psanchez 09-02-2004, 11:02 AM With the engine OFF Remove the duct from the air filter box to the throttle body...spray some choke cleaner into the throttle body and scrub the housing and blade with a soft tooth brush..spray again and wipe clean. There are some GM TSB's on this concern also this is probably a dumb question but what does GM TSB's mean? bullentins? GMMerlin 09-02-2004, 01:01 PM General Motors Technical Service Bulletin bartlanz 09-02-2004, 05:17 PM Depending on your milage, I might also think about doing your fule filter. Could be that when the vehicle is at speed is it sucking it through, how ever at idle it may not have enough emph to do it. Just and idea. GMMerlin 09-02-2004, 08:14 PM Depending on your milage, I might also think about doing your fule filter. Could be that when the vehicle is at speed is it sucking it through, how ever at idle it may not have enough emph to do it. Just and idea. Good thought, but this system does not "suck" gas, the fuel pump pushes fuel through the rail..a clogged fuel filter will cause a problem during high demand (acceleration) psanchez 09-03-2004, 12:31 PM Depending on your milage, I might also think about doing your fule filter. Could be that when the vehicle is at speed is it sucking it through, how ever at idle it may not have enough emph to do it. Just and idea. thank you so much for you response and idea, but i have changed my fuel filter, because i was also thinking it was that, but it still stalls, but atleast i have a new fuel filter. thanks. PC Gator 09-28-2004, 11:17 PM Just wondering if this helped your problem. My wife's '01 LT is experiencing the same problem along with a hesitation at idle. It has just started.....only stalled once while parking. I just got back from running to the store and the hesitation at idle happened to me. I asked her about it and that's when I found it had stalled once. I'll do a search for the TSBs. Any site better than the others? Thanks in advance. DucksZ 10-02-2004, 11:04 PM Anyone find any solutions to there problem? My wife's 2000 LS Tahoe has the same problem. It's been getting worse and worse. I had the same thing happen with the low fuel light coming on even though I had 1/4 of gas. DucksZ 10-04-2004, 10:04 PM For future readers looking for a possible solution. As mentioned by GMMerlin, thanks, cleaning the throttle body solved the problem. I have a 2000 Tahoe(new body style). The throttle is electronic no cables. There is no IAC (idle air control) that I could see. So, my conclusion.. since the throttle is electronic it can be control by the PCM and simulates the IAC to maintain a set idle. The build-up on the the throttle body confuses the PCM causing an erratic idle and stalling. After cleaning the throttle body the idle was solid no irratic idle. PC Gator 10-04-2004, 10:24 PM Same here. Cleaned the TB and the idle went back to rock-solid steady. lahabradq 11-17-2004, 12:17 PM Selman Chevy in Orange, Ca recommends cleanning the throttle body every 30,000 miles(aprox $45 at dealer) if you can't do so on your own. A fuel additive to the gas tank on occasion may help prevent frequency. magglepuss 12-01-2004, 01:21 AM if this problem only happens when your foot is off the gas pedal, I would recommend you clean the throttle body first. Thank You Merlin. I didn't want to spend 200 to 300 dollars to have stalling problem fixed at dealer. Thanks to you I spent $1.06 on carb cleaner, cleaned throttle body, and have corrected stalling. littlebrokenwolf 12-10-2004, 02:00 AM I have a 1999 Chevy Tahoe that is stalling at low speeds of 45 mph or less, I have cleaned the throttle body, installed New Chevy Fuel Filter, new plugs, new plug wires. If anyone can help me please email me at: harclass@aol.com. Thanks for your help as this is getting to dangerous to drive as this is happening all the time. Thanks, Larry Little Broken Wolf. Peekholes 11-02-2006, 10:53 AM I dont want to sound like a idiot but oh well :) I have a 2003 tahoe mine stalls as well at low speeds like 5mph or lower. I have to kinda keep my foot on the brake and gas at the same time at those speeds. Where is the throttle body? And one can show me a pic so I can clean it. Whould a o2 censor cause this as well? Thanks Peekholes 11-02-2006, 09:38 PM Well wanted to update some for everone. I found out where the throttle body was lol and cleaned that. Then changed out all the plugs and wires. Then added some Tectron fuel additive. Doing all that has improved my problems 90%. I think I may do a deep cleaning on that throttle body, the one top part where you can put a small screwdriver was slap full of crude. And there is still some crude I need to get to. Either way this forums members has helped my problem 90% thank you :) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
