88 Cherokee shook violently then died
jwent
08-31-2004, 06:30 PM
I was on the freeway the other night and my Cherokee started to lurch and shake. I then lost power and it wouldn't start for a few minutes. I had to have it towed home and now it will only run for a 30 seconds to a minute before it dies again. After sitting for a few minutes it will start again but then dies shortly after.
Saudade
09-02-2004, 09:18 PM
You'll need to determine if it's an ignition or fuel problem.
How comfortable are you with troubleshooting?
jwent
09-03-2004, 01:45 AM
I'm pretty sure that I've got spark. I just had the CPS replaced because it wouldn't start. It ran fine for about a week then this happened. Before I had the CPS replaced I checked the coil and replaced the distributor and rotor.
I was thinking about replacing the fuel filter. Some one suggested that it might be the fuel pump resistor so I am also considering that angle. The only problem I have is that I'm not sure where the fuel pump resistor is located.
Saudade
09-03-2004, 04:37 PM
The ballast resistor is located on the inside of the fender well next to the air cleaner assembly. It's a block of white-ish ceramic with 2 wires (one at each end).
