93 - Cruise control not working!!!papamac65 08-27-2004, 04:00 PM :banghead: My cruise control on my 93 villager does not work. Has anyone had this problem. I can't find a fuse labeled for the cruise control and I can't find a wiring diagram. Also the "door open" light stays on all the time. The rear door is the culprit i believe because the lights on the door would also stay on. Does anyone know where the switch is on the rear door??? Thanks in advance Dave jackass#1 10-04-2004, 10:50 AM had same problem on my rear door on a 95 make sure the latch trigger is tighten and also the latch on the door is not lose. that has my problem it wasnt latching properly becuase they here both lose. i believe the door sinsor is on the latch its self in the door. well i hope that helps. still searching on your cruise problem. all i know is that the fuse for it is under the hood. c-tex 12-07-2004, 06:51 PM did you ever figure out whats causing the cruise control problem?? same thing happened with my 94... it worked fine then one day it quit working and i cant find a fuse labelled for it anywhere. nothing in haynes either. krisjaz 06-23-2005, 11:28 AM I have a 94 Villager and my cruise just quit working. I can't find a fuse. I just replaced both driveshafts and ball joints and I'm wondering if this has anything to do with it. Please Help! krisjaz 08-15-2005, 10:02 AM Has anybody figured out anything on this? drcoffee 11-28-2009, 04:09 PM Has anybody figured out anything on this? Mine stopped working. The problem was the vacuum line came off. While I was replacing the AC receiver it must have been yanked. The cruise was working and then just stopped. For anyone with sudden complete failure of the speed control, check your Vacuum line from the Vac control modual to the passenger side of the intake. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
