Auto Headlights Off 92 CamryThrasher086 08-26-2004, 01:06 AM I had my 92 Camry for over a year and from cars.com it said my XLE V6 came with auto headlights off. Well mine never went off till today when i shut the engine off, the lights went off to my surprise. So when I went back home to see if it will go off again, it didnt when I shut the engine off. Does anyone have an auto headlights off problem? Maybe it is the wiring? phisigbrotha 08-26-2004, 09:08 AM my auto off headlights turn off when the driver's door is opened. luther Bossman 08-27-2004, 04:22 AM If I remember correctly, my 92 Camry headlights timed out and turned off automatically a couple of minutes after I got out of the car. trexx85 08-27-2004, 01:11 PM soon as i take out the key the lights turn off on my 1993 xle. Thrasher086 09-03-2004, 04:36 PM Ok I noticed sometimes when I open the driver side door it doesnt register that I opened it on the dashboard. So when I shut the car off and open the door the lights don't always go out since the door opening doesnt always register with the computer. Anyone know how to fix it? Maybe a wire is lose a bit which makes connections sometimes but not all the time or maybe it could be a relay? Mike Gerber 09-04-2004, 05:28 PM Thrasher086, It could be as simple as the button that registers when the door is open or closed is sticking closed at times. If it's the same as my 94 it's in the frame of the car where the door closes just below where the the striker is, but it's on the frame. Pull back the rubber cover from the bottom and you will see 1 10mm hex head bolt. Remove the bolt and pull the button out just slightly. Now just clean the button up with some WD-40 from the backside and work it a bit. If it is sticking, this should fix it. You can also observe if the wires there are connected or corroded. If it's working sometimes, it should be connected. The WD-40 will also clean the corrosion, if there is any. Mike Thrasher086 09-05-2004, 08:44 PM WD-40 worked like a charm. Thanks man! Mike Gerber 09-06-2004, 01:14 PM Thrasher086, You're welcome. Glad it worked for you. Mike vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
