porting help!!!
riff22
08-25-2004, 01:06 PM
i have a 2 gen talon tsi, what is all good to port? im planning on gasket matchin. just dont know what all to do. is it a big gain with a stock turbo? should i even do this?
thanks tyler
thanks tyler
IhatetheHyena
08-25-2004, 01:30 PM
02 Housing, Turbo exhaust side - wastegate hole, Head - port and polish the exhaust side and never polish the intake side. Just port. Keep in mind when you gasket match you can't just bell it out and expect that to surfice. It must be a smooth plain to the transition.
coolguycooz
08-25-2004, 05:34 PM
Hey is porting when you make stuff smooth so air and exhaust can travel through it faster?
helliviknow
08-25-2004, 07:02 PM
naw ur thinkin polishing porting is actually removing material to free up flow
10.5sec92AWDTALON
08-25-2004, 07:58 PM
Given the fact that most fuel injection hits the valve theses days there's no reason not to polish the intake side. That was a thing years ago when you were running a carb, you tended to get fuel separation from the air/fuel mix with too smooth of walls.
