Tahoe rearview mirror temp malfunction
Google
Web AF
richone
08-22-2004, 05:13 PM
The temperature reading on my 2000 Tahoe reads "OC" instead of an actual temperature setting. Can anyone tell me how to correst this problem?
Thanks
95ragtop
08-31-2004, 01:50 PM
OC means Open Circuit. The temperature probe behind the front grill has gone bad or one of the wires has broken. To check the wiring, unplug the sensor behind the grill. Use a wire to short across the two connector pins. If the wires are ok, the mirror will read SC for short circuit. This means the probe is bad. Probes should be avail. at your local dealer. Good Luck.
zcmaniac
11-30-2005, 11:36 AM
Mine reads 60 degrees all the time no matter what the actual outside temp is could this be the same reason?
528alb
09-24-2007, 10:02 PM
Mine reads the compass part fine, but when I press "Temp", it goes blank until I press the "Comp" button again. Any ideas?
Google
Web AF
