89 cherokee stalls turning corners!!
bugmenot
08-21-2004, 05:09 PM
I have no clue why it's doing this. Does anyone have any ideas?? It's an automatic and it starts up right away after it stalls, it does it when I'm off the gas turning or sometimes if I haven't driven it in a few days, it happens when I'm stopped , off the gas, like at a red light. Help?
Dale Aeppli
08-21-2004, 09:11 PM
HI, IT SOUNDS LIKE THE CRANKSHAFT POSITION SENSOR MAYBE GOING BAD. ITS MOUNTED ON THE BELLHOUSING. DALE
jeepman600@aol.com
kmerian
08-24-2004, 11:31 AM
My Jeep did that, when was the last time you replaced the fuel filter? Replaced mine and gave it a full tune up and that put an end to it.
xj31
08-24-2004, 09:32 PM
crank sensor is very likely.also could be an egr problem.try pulling the vac. hose off the egr valve .see if that helps
JeEpBoY95
08-24-2004, 11:23 PM
sounds like a fuel pump to me.....especailly if it only happens when you turn. i might be the fuel filter too
