csfi need to replaceritz93 08-21-2004, 04:01 PM anybody know where i can pick up the csfi injector for a 1996 s10 blazer 4.3 vortec VIN W. besides GM? SWEATBREAD 08-21-2004, 05:41 PM Yes, Napa Auto Parts. Part # Crb 218634 BlazerLT 08-22-2004, 01:37 AM You sure you need to install a new one? How do you know? They don't fail on the 1996. Jeremy-WI 08-22-2004, 07:40 AM I would not replace it with another CSFI unit, I'd get the MFI replacement from GM. About $200 plus S&H online. Part numbers are 12568332 MFI Spider assembly: 88894355 Bracket(can reuse old one): 17113215 seal kit. These part numbers are for a V6 ritz93 08-22-2004, 07:54 PM You sure you need to install a new one? How do you know? They don't fail on the 1996. my mec. said she was misfiring on cycl. no. 6, i bought it in to him because it had a realy rough idle and very hard to start. he told me it was the injectors. you said the dont fail on the 96 but i thought iread some of the same problems on 96 and up. on this site. would you suggest something different? i'm all ears BlazerLT 08-22-2004, 08:14 PM I suggest you replace the poppet valve going to the 6th cylinder then, not the whole unit. Have you done a tuneup or anything? Are you getting any check engine codes? ritz93 08-22-2004, 09:22 PM just cahnge that one line to the 6th cylinder? i was going to change the fuel regulator as well. i got engine codes when my mech. scanned it, i had brought it in for a tune up. he changed thing , the idle got a little better but not much. the check engine light comes on and flashes at idle. i thought it was better to change the whole unit, but i know they sell the poppet valves alone for around 80 bucks your probably right. i was concrened with other ones being or going bad. BlazerLT 08-22-2004, 10:09 PM You need to ask your mechanic what the codes were. Do you know them? Not the description, the actual numbers. ritz93 08-23-2004, 09:55 PM i'll have to ask him what the codes were, i thought i had them writen down. the ticket he gave doesn't have the codes on it, he only wrote problem with fuel injector. BlazerLT 08-23-2004, 10:49 PM And that is why I would be suspecting his diagnosis. ritz93 08-23-2004, 10:52 PM do you think he's full of it? and that not be the problem????? BlazerLT 08-23-2004, 10:54 PM Well, It might be, but I am not liking the lack of details in his synopsis. Too general. Get the exact codes and we can go from there. ritz93 08-23-2004, 10:57 PM you got it get back to you tomorrow, thanks BlazerLT 08-23-2004, 11:00 PM BTW, have you taken off the EGR valve and checked for chunks of carbon? ritz93 08-23-2004, 11:01 PM yes took it off, it was fine moved easy didnt look too bad. BlazerLT 08-23-2004, 11:06 PM Ok, and also, when he is getting the codes, be there and see it on the machine itself. Don't have him come out with a book and point to it, make sure he shows you the code on the scanner. Better yet, get the codes read at Autozone for free for a reference. Also, you never told me if you have ever done a tuneup and what it detailed? ritz93 08-23-2004, 11:11 PM okay i'll check that out, i did get a tune up thought i said that, plugs, wires, cap and rotor, new fuel filter, pcv, air filter. do you think it sounds like something else, ever come across anything like this one? i'll get those codes. BlazerLT 08-24-2004, 12:01 AM Well, before I make any shots in the dark, I would like to see the codes first. ritz93 08-24-2004, 04:13 PM hey blazerlt got scaned the code came up po306. even clinton's says that code is a misfire on 6. what do you think? should i replace the poppet valve and see what happens? BlazerLT 08-24-2004, 09:10 PM First, check the distributor cap for a bad connection. Take it off and check for corrosion. Second, you don't have tyo replace the whole fuel injection unit. Only replace the 6th clylinder fuel injector. For example, it looks exactly like this: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7917565682&category=33557 The 6th cylinder is the passenger side cylinder closest to the firewall. That should set you right up. Buy a Haynes or Chilton repair manual for US$15 and do it yourself. It is fun learning how to do your own maintenance. ritz93 08-25-2004, 05:11 PM Thanks Blazerlt For All Your Help. Will Let You Know How All Turns Out. BlazerLT 08-25-2004, 05:36 PM Yes, please do. BOOMERBOWL 08-30-2004, 06:30 PM If You Change From A Csfi To A Mfi, Does The Computer Have To Be Reprogramed? Does Mfi Help Performance? Jeremy-WI 08-30-2004, 07:57 PM no reprogram, and if it helps performance its just because the injectors are new and not gummed up- same size injectors as csfi but no poppet valve BlazerLT 08-30-2004, 11:19 PM But realistically, a complete fuel injection system change because of one single injector is a little idiotic and a complete waste of money. Replace the injector and enjoy. ritz93 08-31-2004, 09:08 PM replaced the bad injector today. it wasn't very hard at all, clintons gives good instructions. she runs like new. all is well thanks for the tips blazerlt BlazerLT 09-01-2004, 01:21 PM WOOHOO! Love to see a fellow blazer owner back on his feet. You just saved yourself some serious money. Injector Jim 09-29-2005, 07:21 PM anybody know where i can pick up the csfi injector for a 1996 s10 blazer 4.3 vortec VIN W. besides GM? Hi Yes I do know where you can get a exchange csfi assy. With a one year warranty. The number is 845-536-7600 Price I believe is $275.00 with your old core unit after you sway them out. Glad to be of help. Thank you Jim Injector Jim 10-06-2005, 03:56 PM anybody know where i can pick up the csfi injector for a 1996 s10 blazer 4.3 vortec VIN W. besides GM? My name is jim from the injector perfector.I have exchange csfi assy. They come with a on year warranty. Your cost is $199.95 with your old core. My number is 845-536-7600. or my email address is injectorjim@aol.com My website is theinjectorperfector.net Thank you jim blazee 10-06-2005, 05:38 PM Hello Jim and welcome to the forums. We are always happy to get new members, but there are some rules that everyone must follow. Please read the Forum Guidelines: http://www.automotiveforums.com/vbulletin/guidelines.html "POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread." "ADVERTISING Advertising is prohibited on the forums. Your membership will be revoked at first such offense." That was posted a year ago and he said his problem has been fixed, I don't think that he wants to buy your injector assembly. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
