automatic shift knob
View Full Version : automatic shift knob automatic shift knob lucki17 08-19-2004, 05:30 PM cody911911 08-19-2004, 05:49 PM what kind of shifter on the column or on the floor? lucki17 08-19-2004, 07:18 PM its on the floor. Andydg 08-22-2004, 01:14 AM I think I saw one in Summit or JC Whitney's sport compact section. bcustom561 08-22-2004, 10:20 PM you can just take off your old shifter and cut the overdrive wire. this will make the overdrive stay on forever unless you splice the wires and hook them up to a switch. then you cand put on another shift knob. this is what i did for my 98 corolla earlier today and it worked perfectly lucki17 08-22-2004, 10:27 PM i was accually kindof thinking that but i didnt know if the o/d was a wire or what, what did you do about the push button for selecting gears? eckoman_pdx 08-31-2004, 07:24 PM Autofreak has several auto shift knobs with OD. I know several of them work with Nissans. http://www.autofreak.net/shiftf.html Click on the link, and then click on Automatic Transmission. Look for the ones that list OD in the discription. Those should be the ones that will work. You can click on the link under discription for more info on each. I hope this helps a bit. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
