what should i set timing at?
eightcylS10
08-19-2004, 04:26 PM
what shoudl i set my timing at with a 86 305? just curious because i cant find it in any books or anything so i was just wonering if anyone knew what it should be set at...thanks
stangzilla
08-23-2004, 07:06 PM
any mods made to the engine? let us know as much as possible and intended use.
eightcylS10
08-24-2004, 10:34 AM
no mods, the engine is the L69 305 with is the HO version, all i have done is dualled the exasust took ou the cat, and thast all, i plan on using it for a daily driver, but also i plan on running it at my local drag strip..thanks for the help.
TweakedGM
08-26-2004, 04:49 AM
8 degrees for economy or 10to12 degrees for performance.you will know if you gone to far if it starts to ping.
TechX
08-28-2004, 11:47 PM
I have seen balancers actually twist and throw off the timing markings from where they should be. I now do my timing on old engines the quick and easy way. Retard then advance and find a sweet spot in the middle. A few times doing this and test driving you can get an engine running very close to perfect. Only after I have the engine running great will I put the light to it and check the markings.
