rear wheel sqeak
mkatts
08-19-2004, 03:03 PM
Hello all,
'99 blazer LT 4dr, 4wd. I have had a squeaking in both the drivers and passengers side rear wheels. The sqeak sounded just like a wear indicator on a worn brake pad. I found that the brake caliper slides had frozen in the bracket and the rotors were all chewed up. I replaced the rotors, and replaced the brake pads with Raybestos ceramic, quiet stop pads. I was able to break the slides free and repolish them and the bracket. coated all wear surfaces with lithium grease.
I still have the dame sqeak. :banghead: The sqeak only starts after having driven the truck for a while when it warms up. I was in a parking lot and noticed the sqeak intensified on the left when I turned had right and then intensified on the right when I turned hard left. The drivers side axle bearing has small amount of up/down play. The passenger side does not have any. Driving straight the sqeak is more prominent on the passenger side. I am thinking it's the axle bearings, but there is a small part of me that thinks maybe these ceramic pads are the problem as I have never used them before. I have seen a spray lube by bendix that you spray on your rotors and pads to stop brake sqeak, but I have a hard time thinking that stuff is a good thing to use. I am leaning towards the bearing but wanted to your opinion.
Thanks in advance
Rbraczyk
08-19-2004, 07:37 PM
I had a frozen front caliper and all it did was squeak all the time. Your probably gonna need to replace both calipers.
ajk114
08-20-2004, 12:50 AM
I'm running Bosch ceramic pads in my wife's 99 Envoy for the last 18K miles, they do not squeak/squeal. A worn or rough axle bearing would be noisy all the time. Agree with the previous post, sounds like the issue is with the calipers.
Good luck,
BlazerLT
08-20-2004, 03:04 AM
Sounds like you might have cooked the rear bearings.
mkatts
08-20-2004, 02:35 PM
I have a hard time believing it's the calipers. Wouldn't the calipers squeek when I apply the brake? This squeek does not change in pitch or volume at all when I step on the brake. No affect what so ever. The only thing that affects the noise is the speed I am going. If it were the caliper, then i would think there was contact from the caliper to the rotor which i have already verified is not the case.
Anywhere from 0-10mph and it squeeks. After that it quites down.
I thnk I am going to replace the bearings first. Might try the u-joints next.
BlazerLT
08-22-2004, 08:19 PM
U-joints never squeak.
Rbraczyk
08-22-2004, 11:42 PM
Yea he's right, the u joints dont' squeak, No the Piston won't squeak the same when you put the brakes on.
BlazerLT
08-22-2004, 11:49 PM
Yea, I can pretty well guarantee the bearings are gone or the rear brakes need servicing.
Are they rear disc or drum?
I could have sworn they didn't have disc on the back.
Rbraczyk
08-22-2004, 11:58 PM
Anythings possible. i would try to grease the bearings first and see how it runs, then replace em if the noise doesn't stop.
mkatts
08-23-2004, 10:18 AM
BlazerLT,
It does have rear disc brakes. I just replaced them 2 weeks ago along with the rotors. When the squeek started, that is what I thought the squeek was. I replaced the rotors abd pads. Repolished the slides becase 2 of them, one on each side, were frozen in the abutment bracket. I used the brake lube stuff on the back side of the pads. The pads are Raybestos quite stop ceramic pads. They even came with a sticker of some sort that goes on the back side of the outboard pad. My factory pads had the same sticker on them.
I realy think it's the bearings. I am going to replace them next weekend.
BlazerLT
08-23-2004, 02:10 PM
good luck and let us know.
mkatts
08-23-2004, 02:33 PM
will do, thanks for you opinion.
