VTEC questionmengy 08-17-2004, 11:10 AM I just did a y8 swap to my b7 head (see other thread for info) I'm still waiting on the p28 ECU but I rigged a "vtec" button. When the engine is off and you press it you can hear the solenoid click and when the i press it going wide open throttle at around 5,200rpm i can hear it clearly. This morning was the first time I tried in 3rd gear... the car was pulling along pretty good taking forever to get up to speed with the old dx tranny... i pressed it at 5,2000rpm and the engine screamed but the pull stoppped... so i let go and the engine picked up again... Now my question is: Is it because I don't have the ECU yet and it's getting extra air but not more gas?? I checked my oil and everything before I left this morning and my engine was up to running temp when i pressed teh vtec button, or could it be other factors, such as my dx throttle body? dx header? i_a_n112784 08-17-2004, 01:28 PM I would say it's the ecu. It shouldn't be sending anymore gas at a certain rpm because it's not a v-tec ecu. Get the right ecu and it should work. jcrx 08-17-2004, 02:01 PM When did it stop pulling, those cams only make power so high then it flats. jcrx 08-17-2004, 02:07 PM When did it stop pulling, that cam only make power so high then it flats. mengy 08-17-2004, 07:33 PM well without pressing the button it'll stop pulling at around 4,500rpm but it'll keep up the speed climb but if i press the button it'll almost stop pulling. mengy 08-18-2004, 11:41 AM I got the ECU and the wires hooked up. I got rid of the dumb button a long time ago. I was asking if there was anything else I should check because the car feels weaker when vtec hits with the ECU. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
