93GC cranks but no start, check engine light!!nart86 08-17-2004, 12:08 AM hi, I'm having trouble with my jeep laredo It cranks but doens't start It takes like 4 times to start but today it took like 10 times in the cold. I noticed that it doesn't start unless the check engine is on. all the other lights come on exept the check engine light. It takes a few times to appear. I don't think it's the fuel pump cuz i hear it clicking immedtly after turning it on. I also don't have any problems with acceleration or idling. I'm going to change either the crankshaft postion sensor or camshaft.... but I don't know which . I recently did a tune up and I have spark. need help asap thanx nart86 08-17-2004, 11:50 AM hi, I'm having trouble with my jeep laredo It cranks but doens't start It takes like 4 times to start but today it took like 10 times in the cold. I noticed that it doesn't start unless the check engine is on. all the other lights come on exept the check engine light. It takes a few times to appear. I don't think it's the fuel pump cuz i hear it clicking immedtly after turning it on. I also don't have any problems with acceleration or idling. I'm going to change either the crankshaft postion sensor or camshaft.... but I don't know which . I recently did a tune up and I have spark. need help asap thanx I just let some mechanic take a lokk at it . He said he needs to dianose it for 75 lol. I checked the codes and got code number 13. does this have anything to do with my problem. I also told him that it might be from the CPS but he doubted it saying that it has nothing to do with the check engine light. and that it would never start up. He said it might be the computerbut i don't trust him lol. as i said my car doesn't start until it sees the check engine light and the mechanic says it always has to be on and that the CPS doens't effect the check engine light. thanx ByronP 08-18-2004, 07:51 PM From what I could find a 13 check engine code is - No difference recognized between the engine MAP reading and the barometric (atmosphere) pressure reading from start-up. So you may want to have the MAP sensor checked out. ByronP nart86 08-18-2004, 11:24 PM I just let some mechanic take a lokk at it . He said he needs to dianose it for 75 lol. I checked the codes and got code number 13. does this have anything to do with my problem. I also told him that it might be from the CPS but he doubted it saying that it has nothing to do with the check engine light. and that it would never start up. He said it might be the computerbut i don't trust him lol. as i said my car doesn't start until it sees the check engine light and the mechanic says it always has to be on and that the CPS doens't effect the check engine light. thanx how much would it cost thanx ByronP 08-20-2004, 12:37 AM I think a new ECU is around $300 and NAPA shows a new MAP is $40 for the I6 and $80 for the V8. Not sure what it would cost to get it checked. You may be able to test it with a decent multimeter but I can't say for sure as I've never had to diagnose one. ByronP YtseJam454 08-20-2004, 09:39 PM If it has Spark and Injector pulse then you don't need a Crank sensor! Just because you hear the fuel pump doesn't mean you have adequate fuel pressure. You NEED to check your fuel pressure! It should be 31 PSI at idle, 39 PSI with the vacuum hose off of the fuel pressure regulator. xj31 08-21-2004, 07:56 PM it sounds like you need a pcm.thats what turns the check engine light on and if it doesnt come on when you first turn the key on it wont start.you can try turnung the key on and wiggle the connector at the pcm and see if it gets the light to come on.I have seen this problem several times.You might want to check with a dealer on a mopar reman pcm.They had some but off the top of my head i dont know if they have one for yours. nart86 08-26-2004, 12:22 AM it sounds like you need a pcm.thats what turns the check engine light on and if it doesnt come on when you first turn the key on it wont start.you can try turnung the key on and wiggle the connector at the pcm and see if it gets the light to come on.I have seen this problem several times.You might want to check with a dealer on a mopar reman pcm.They had some but off the top of my head i dont know if they have one for yours. bump nart86 09-13-2004, 11:25 PM If it has Spark and Injector pulse then you don't need a Crank sensor! Just because you hear the fuel pump doesn't mean you have adequate fuel pressure. You NEED to check your fuel pressure! It should be 31 PSI at idle, 39 PSI with the vacuum hose off of the fuel pressure regulator. i did a complete test. computser scanner shows nothing. i get spark. fuel pressure is good. fuel pump/relays are good. could it be from the battery? when i put the key to the on position, i only get like 9 or 10 volts and then after firing it up it goes to 14 . is this normal. my dealer says that it could be the igntion switch. he says there is something preventing the fuel pump to kick on (because check engine light takes time to come on) he' s gone crazy and so have i i need some help plz dksob81 09-14-2004, 12:29 AM hi, I'm having trouble with my jeep laredo It cranks but doens't start It takes like 4 times to start but today it took like 10 times in the cold. I noticed that it doesn't start unless the check engine is on. all the other lights come on exept the check engine light. It takes a few times to appear. I don't think it's the fuel pump cuz i hear it clicking immedtly after turning it on. I also don't have any problems with acceleration or idling. I'm going to change either the crankshaft postion sensor or camshaft.... but I don't know which . I recently did a tune up and I have spark. need help asap thanx Code 13- Idicates a problem with the Manifold Absolute Pressure Sensor vacuum source. your problem is not the Camshaft Position sensor, if it was the camshaft Position Sensor, it wouldn't crank at all. but it could be the Crankshaft Position Sensor. but I would have the MAP sensor check out and replaced. b4 you do anything, I am willing to bet that is the problem. dksob81 09-14-2004, 12:34 AM Sry, for my last answer I kinda jumped the gun and didn't read all replys. well since u have spark, I doubt it is the Crank sensor. but I would go ahead and have the MAP Sensor checkd out, doubt if that has anything to do with the Check Engine light not coming on at start-up. dksob81 09-14-2004, 12:36 AM have u ever sprayed any water in ur engine compartment. u might have to disconnect the wires from the PCM, maybe u have condensation in the connectors, and it is preventing it from starting, someone else had that problem with their jeep not starting and thats what the whole problem was. try to d/c it and let it air dry for a couple hours, that might help. nart86 09-14-2004, 10:18 AM yes. the place i bought it from cleaned the whole engine compartment with a high pressure hose or whatever. now , where's the pcs connectors located? im gonna try this one thanx alot bro i really appreicaite it dksob81 09-14-2004, 01:44 PM the PCM connector is loacted on the PCM, it is on the passenger side firewall in the engine compartment, should be behind the Colant Reserve Tank. there is one big connector, about 5" long and 2" wide, and there is a bolt right in the center, just loosen it all the way and pull it out. nart86 09-14-2004, 04:44 PM the PCM connector is loacted on the PCM, it is on the passenger side firewall in the engine compartment, should be behind the Colant Reserve Tank. there is one big connector, about 5" long and 2" wide, and there is a bolt right in the center, just loosen it all the way and pull it out. could it be the battery? cuz i only get 9-10 volts when the key is turned onto the on position. but after starting the car up. it goes to 13-14 is this normal or shoud i just buy a new battery. thaxn dksob81 09-15-2004, 12:08 AM I doubt it being the battery I thought the same thing with mine but it seems to be normal. I have tested the battery, b4 trying to start it in the morning with a MULTIMETER and it tested out good, should be between 11.8 volts and 12.6 volts when not running. I suppose it could be the Ingition Switch. just check, when it won't start just turn the key to the ON position and then open the gas cap and listen for the fuel pump, on alot of cars u can hear it turning on while sitting in the drivers seat, but I even found it hard to hear while listen down by the gas tank. so I opened the gas cap and listened. nart86 09-18-2004, 12:27 PM my mechanic is now telling me it sometimes gets no spark and it could be the crank shaft position sensor. but does that have anything to do with the chech engine light not coming on thanx YtseJam454 09-18-2004, 02:48 PM The place you bought it from probably took the bulb out of the dash. I see that happen all of the time with used car lots. You need to go back to the basics and stop jumping all over the place. A)Spark @ the plugs? B)Injector Pulse @ the injectors? C)Fuel Pressure D)Compression E)Timing Let us know the results. tdenkler 09-18-2004, 04:20 PM if you have factory security system, I have a ecm you can have for $100. I'll pay shipping. I was trying to solve alarm issue and turned out to be a sensor(doesn't it always?) Tom Denkler email: tdenkler3853@earthlink.net nart86 09-18-2004, 11:34 PM The place you bought it from probably took the bulb out of the dash. I see that happen all of the time with used car lots. You need to go back to the basics and stop jumping all over the place. A)Spark @ the plugs? B)Injector Pulse @ the injectors? C)Fuel Pressure D)Compression E)Timing Let us know the results. what bulb are you talking about and i do have all those u listed thanx YtseJam454 09-19-2004, 08:04 AM I thought you had said your check engine light was not coming on. The bulb in the dash is what I was talking about. So you have spark available at the plugs, you have adequate fuel pressure, you have injector pulse, you have good compression, and correct timing. Then let's look at it like this, what else could cause the engine not to start? Either the spark plugs are fouled possibly due to over fueling or being soaked in coolant. What could cause too much fuel? A faulty MAP reading or engine coolant temp would be the most likely cause of it actually not even starting. If your TPS was faulty it would set clear flood mode if it was reading over 4.3V at idle but you would have no injector pulse which you said you had. Here is what I would suggest. Pull all of the spark plugs and check them. If they are wet with fuel you have an overly rich condition. Check the MAP and engine Coolant temp sensors. Replace the spark plugs and make sure you have no obstructions in the induction system, like a mouse nest in the air cleaner. Good luck. dksob81 09-19-2004, 07:42 PM the CHECK ENGINE light is effected by the Crankshaft Position Sensor. whe the CHECK ENGINE light comes on, during ignitial start up or when key put in the ON posistion the light comes on (this tells u that the engine has ran the innitial diagnosis and everything checks out) most common reason for it not to come on is b/c of the Crankshaft Posistion Sensor, the computer is not getting a proper read or it is just not responding theref or the computer won't allow any othe operation to perform( Fuel pump, Injectors, Ignition Coil). take the gas cap off of the Fuel Tank, and have someone turn the key to the ON posistion if u here a whirring sound then the Fuel Pump is working correctly. if not then it is most likely the CPS. the fuel pump could still operate and have u may still have a bad CPS. I dunno, bottum line I would start at the CPS. change it and c what happens nart86 09-20-2004, 11:38 PM hi everyone. I just go my car back from some mechanic and he said that there's no fuel, pressure. spark.igntion pulse . etc... he said it could be the wires that go to the computer or the computer itself could be bad. he said that there's like 30 wires to check and that would cost 125 .damn it I just took a look at the wires and saw one pink wire which was bare for like an inch but wasnt really touching anything. could that be my problem . lol i hope so dksob81 09-21-2004, 12:35 AM well if it's not touching any metal, then I would say no, but put some electrical tape around it just incase. but what u have described sounds like the Crankshaft Posistion Sensor is bad. I would check that out 1st. read what I wrote above. nart86 09-21-2004, 12:10 PM this mechanic said that the crankshaft position sensor was good. he said it wasn't getting any ground or whatever to it. neither do all the fuses and relays etc... how much would it cost for a cps? with labor and everything. i kept telling this guy it may be the cps but he argued heavly that its the computer dksob81 09-21-2004, 11:39 PM depending on which engine u have. 5.2L is 41.99 . and 4.0 there is a couple brands ranging from 42.99 to 65.99. check autozone. I was speaking with anopther guy who is changing his, and he was gonna have the dealer do it, but it would cost $400. and believe me it is not worth $400 it will take like an hour-2hours tops if u do it urself. if u need directions email me Joe, dksob81@hotmail.com dksob81 09-21-2004, 11:40 PM I meant instructions.....lol email me dksob81@hotmail.com nart86 09-28-2004, 11:49 PM ok so my mechanic changed the crank sensor but the car started running like crap. rpm's were jumping and the car was like farting lol. so he put the old crank sensor back in .the car runs fine now but it still has the major problem. maybe he put in a wrong or faulty sensor. he's ordering a new one by saturday. there is something preventing the damn fuel pump, ignition , spark plugs etc.. to work. i"m thinking that it could be the factory alarm . how can i permantly disbale it.??? also, i have a question. when u put ur key in and on to the on position and wait a few seconds . Does the security light come on on the dash? thanxxxxxxxx nart86 09-28-2004, 11:51 PM plus when my mechanic hooks up his computer to the truck. it says no data. dksob81 09-29-2004, 12:46 AM I woul dhave to say that the new CPS (Crank position Sensor) was faulty. and no the Security light doesn't come on in my jeep (1994 Jeep grand Cherokee Limited 5.2L) when I turn the key to the ON position. I will check again in the morning just to make sure. nart86 09-29-2004, 12:36 PM the security light comes on after leaving the key in for like 40 seconds can u plz check urs dksob81 09-29-2004, 07:25 PM sorry I forgot to check this morning, I will check as soon as I get home. darko 12-25-2004, 03:55 PM Dude! Any developments on your starting problem? I was poring over the forums (fori?) and your case is EXACTLY like mine - ie: no check-engine light = no start. If/when it flashes on, I know it will start. Mine's been in the shop for weeks, trying all sorts of stuff (crank sensor etc.) but no dice. Just curious if / how yours was solved. Thanks Dale Aeppli 12-25-2004, 05:40 PM Dude! Any developments on your starting problem? I was poring over the forums (fori?) and your case is EXACTLY like mine - ie: no check-engine light = no start. If/when it flashes on, I know it will start. Mine's been in the shop for weeks, trying all sorts of stuff (crank sensor etc.) but no dice. Just curious if / how yours was solved. Thanks HI, HAVE YOU CHANGED THE CRANKSHAFT SENSOR. DO YOU HAVE SPARK AT THE COIL WIRE. YEAR, MAKE, MODEL AND ENGINE , AND ANY OTHER INFO YOU HAVE ON PROBLEM DALE jeepman600@aol.com :2cents: darko 12-25-2004, 06:02 PM Aha! The famous jeepman! I almost emailed you before posting. Crankshaft sensor replaced - no dice. It is a 93 Grand Cherokee limited with the inline six cylinder engine and selectrac 4x4. I'm starting to suspect the ECM module or connections to it, maybe the relay (thus the no check-engine light when it won't fire). Thanks Dale Aeppli 12-25-2004, 06:08 PM Aha! The famous jeepman! I almost emailed you before posting. Crankshaft sensor replaced - no dice. It is a 93 Grand Cherokee limited with the inline six cylinder engine and selectrac 4x4. I'm starting to suspect the ECM module or connections to it, maybe the relay (thus the no check-engine light when it won't fire). Thanks Does the gauges on dash work when you turn key on dale can you hear the fuel pump relay click when you turn key on darko 12-25-2004, 06:12 PM The gauges work; nope, can't hear the pump. Also, this started (could be a coincidence) when the weather turned colder. Just when we need a Jeep most. However, when the Check-engine light DOES light up, then it DOES start, and I can hear the pump, and a major click/buzz from pax-side firewall (near the ECM?) Dale Aeppli 12-25-2004, 06:17 PM The gauges work; nope, can't hear the pump. Also, this started (could be a coincidence) when the weather turned colder. Just when we need a Jeep most. However, when the Check-engine light DOES light up, then it DOES start, and I can hear the pump, and a major click/buzz from pax-side firewall (near the ECM?) if yours has a power distribution box remove lid look and see what relay is for ASD change the ASD relay with one of the other relays, they are all the same. email me i can get back faster jeepman600@aol.com dksob81 12-25-2004, 08:08 PM DARKO, was the brand of CPS you used Borge Warner or something like that, if so replace it with a different brand EICHLIN is a good one. nart86 12-27-2004, 12:20 AM DARKO, was the brand of CPS you used Borge Warner or something like that, if so replace it with a different brand EICHLIN is a good one. dude. u need to replace the computer. just stop poring money into the jeep and get a new computer. all my problems have been gone ever since. darko 12-27-2004, 07:01 AM Thanks for the info! I was hoping to hear from you as the symptoms are bang-on same as yours. Now the hunt begins. Car-part.com lists them but I've never seen so many options to choose from. Have to check my data. Thanks darko 01-08-2005, 11:43 AM And...voila! Same thing. Replaced the computer and that did it. Still waiting for the mech's bill for all the dorking he did before this... mikec041 01-08-2005, 06:07 PM Detail shop i took my GC to a while back would not touch engine compartment due to the sensors being to fragile. Check the connector at the MAP sensor for corrosion go to radio shack and pick up a can of contact cleaner and try cleaning the connector to MAP before you replace it. PrestonP 01-18-2005, 07:04 PM Dude! Any developments on your starting problem? I was poring over the forums (fori?) and your case is EXACTLY like mine - ie: no check-engine light = no start. If/when it flashes on, I know it will start. Mine's been in the shop for weeks, trying all sorts of stuff (crank sensor etc.) but no dice. Just curious if / how yours was solved. Thanks Darko, so the replaced computer fixed all your problems? I have the EXACT problem - plus - my alarm has been going off at strange hours of the night. In your experience, do you think that the starting issues and the alarm are connected in some way? Glad to hear the jeep is all better now. thanks darko 01-18-2005, 07:35 PM So far so good; the problem hasn't come back, although one morning I had a scare. But yes - the computer did it. I got a reman online; 275 plus core deposit 100 which you get back. Seems cheaper in the long run, and saves a lot of heartache each time a new fix doesn't do it. Not sure about the alarm affecting the computer; mine wasn't bleating, except after looooong cranking it would beep a couple of times. PrestonP 04-28-2005, 02:49 PM Nart86, I would like to know if replacing the PCM was something that a guy could do on his own? I had the very same problem that you have, but it mysteriously went away. Now, it is back. You had mentioned that you got the computer replaced (computer=PCM?) and that this solved your starting/check engine light problem. Is it simple to replace? Cheers, PrestonP I would also like to ask some of the famous forum experts (like Dale and dksob81) about their opinions on this problem and the proposed solution. Why do you think that the check engine light refuses to come on? Thanks, you guys are brilliant! Dale Aeppli 04-28-2005, 03:13 PM Nart86, I would like to know if replacing the PCM was something that a guy could do on his own? I had the very same problem that you have, but it mysteriously went away. Now, it is back. You had mentioned that you got the computer replaced (computer=PCM?) and that this solved your starting/check engine light problem. Is it simple to replace? Cheers, PrestonP I would also like to ask some of the famous forum experts (like Dale and dksob81) about their opinions on this problem and the proposed solution. Why do you think that the check engine light refuses to come on? Thanks, you guys are brilliant! HI, THANKS FOR THE HYPE. WHAT EXACTLY IS YOUR PROBLEM ALOT OF TIMES THERE IS JUST SOMETHING A LITTLE DIFFERENT ON EACH VEHICLE. THE COMPUTER IS BASICALLY A PLUG IN DEAL. SOMETIMES, IF YOU CHANGE IT CHECK AND CLEAN THE PLUG CONNECTIONS, LOOK TO SEE IF ALL THE WIRES ARE A GOOD CONNECTION. IF YOU CHANGE IT JUST BE SURE TO DISCONNECT THE BATTERY BEFORE DOING HOPE THIS HELPS DALE PrestonP 04-28-2005, 04:01 PM Dale, thanks for your help. I've just been under the hood and I unplugged the main connection into the PCM and wiped away dust, and other bits that may interfere with the connection. tried to start it again, but nothing. I have a 94 Jeep grand cherokee that will only start once the "check ongine" light clicks on. I put in the key, turn to the on position, and if there is no light, it will turn try to start (starter is working well) but I can guarantee that it will not start up. However, once the "check engine" shows up, it starts and drives nicely. Usually it takes a minute or two of trying before it starts, today - nothing. No matter what I try, the light doesn't show up, and the Jeep doesn't start. I will be very close to my computer today, thanks for your help - I'm going back out to tinker some more... PrestonP PrestonP 04-28-2005, 05:11 PM Well, I finally got it started. I prayed, that may have helped. Actually, besides divine intervention, I really don't know what finally got it running. Like I predicted, the "check engine" light came on and with one turn of the key - vrooom. When I turned it off and tried again, it worked. But when I left if for 20 minutes and came back to it - it took several good tries and another prayer before the "check engine" light came on - then she started nicely. Dale, I sure thank you for your help and I hope I can do you proud by getting her to start on time, everytime. Cheers, PrestonP Dale Aeppli 04-28-2005, 07:01 PM Well, I finally got it started. I prayed, that may have helped. Actually, besides divine intervention, I really don't know what finally got it running. Like I predicted, the "check engine" light came on and with one turn of the key - vrooom. When I turned it off and tried again, it worked. But when I left if for 20 minutes and came back to it - it took several good tries and another prayer before the "check engine" light came on - then she started nicely. Dale, I sure thank you for your help and I hope I can do you proud by getting her to start on time, everytime. Cheers, PrestonP USUALLY WE'VE RUN INTO FRAYED WIRES AND BURNT WIRES GOING TO CRANKSHAFT SENSOR. THE CONNECTORS ON THE CRANKSHAFT AND CAMSHAFT SENSOR CAUSE A LOT OF HEADACHES. LOT OF TIMES WIGGLING THE CONNECTORS WILL LEAD TO THE NO START PROBLEMS. THE 93-96 GC'S SEEMED TO HAVE A LOT OF WITH COMPUTERS AND BAD CONNECTORS ON THEM DALE :smokin: :grinyes: PrestonP 05-03-2005, 11:40 AM Dale, What is the easiest way to access the Crankshaft sensor? My manual says it is on top of the transmission housing- is that true? What would you suggest? Preston Dale Aeppli 05-03-2005, 12:52 PM Dale, What is the easiest way to access the Crankshaft sensor? My manual says it is on top of the transmission housing- is that true? What would you suggest? Preston Give me a holler at jeepman600@sbcglobal.net I :naughty: 'll send picture and instructions Dale adgoitd 05-08-2005, 01:30 AM your chances that your computer is going bad are 98% and you can ask me for information about where to get a cheap PCM/ECM computer not from the foolish dealership, i made the same on my jeep and my problem is solved, i could tell you my PCM cost 240 dollars and i could install it by myself PrestonP 05-09-2005, 01:05 AM sounds great, let me know the details...Where can I get a new PCM? I live in Canada...so I would have to find a source up here... Thanks so much, Preston adgoitd 05-09-2005, 06:15 PM Preston send me an email to my account, and i will let you know, because i don't think they don't allow to post websites here, thank you! adgoitd 05-09-2005, 06:32 PM the problem on the jeeps are the computers, the stock ones are of bad quality because they want to save money and compromise quality, that's why all of us have problems with our cars due to a bad computer, i could predict the lifespan of a computer: 10-12 years and that's all StacyB 05-09-2005, 08:29 PM I am ordering one (computer) today from Schucks for my 93 Wrangler (4.0 l6) because of the same problem. There are several part numbers. You need to match #'s with what you have. My reman. comp. is $131 plus $70 core. PrestonP 05-15-2005, 12:25 PM That seems like a great price. I called the dealer and they want $800 for one! Great find! Are the reman comps. worth it? Let me know how it works out for you Cheers PrestonP rksnc 05-16-2005, 09:32 AM Hay the map code is most likely because the engine hasn't crank after so many starts. It is the running problem that has cause the code. Just because you get a code doesn't mean it is bad. It just said it didn't see the change but why not? Because it did not crank is why. And also I have never had a map sensor to stop one from starting. When it is bad most of time it will run very rich. StacyB 05-16-2005, 12:21 PM That seems like a great price. I called the dealer and they want $800 for one! Great find! Are the reman comps. worth it? Let me know how it works out for you They had to special order and it is supposed to ship on the 18th. Everywhere I looked it had to be special ordered though so no big deal. There were two different part numbers and one was $170 and the other was $130. I was lucky I guess that I needed the cheaper one. I am crossing my fingers that this will fix the problem. I WILL post a response so others (the many) with this same problem can benefit.:) adgoitd 05-16-2005, 02:59 PM rksnc, prestonB is refering about the fact of interal failure in the PCM causing the car not to start right away, the MAP sensor doesn't have to be with the ignition system, it's a part that coordinates the fuel/air mixture into the engine, and besides the MAP sensor gives a code and also if the MAP sensor is bad, the car would hesitate or even stall! PrestonP 05-16-2005, 07:51 PM good point. I discovered that my "check engine" light will come on if I just turn the key to the "ON" position and wait a bit. Some relays click, lights come on, etc. With a few of these attempts, voila, the "check engine" light comes on and VROOM, she starts up perfectly. Hmmm... PrestonP adgoitd 05-16-2005, 08:27 PM haha, isn't funny the way the car reacts to you?, well this was my day off and i spent around 1300 dollars with one saturn, during the last 2 weeks, and now i'm glad my jeep is doing it good, in the past my car was a piece of garbage, right now it's my right hand! ... JUST IN CASE preston! , have you seen one cable (very tiny or thin) that goes near the battery, it's a kind of connector, well that is the ground connector of PCM, try to unplug it and plug it back in, you will hear a very small clicking sound when you have your key at ON POSITION, this indicates the computer is shot , quick diagnostic!! without taking the PCM out of car adgoitd 05-16-2005, 08:32 PM nart86, you don't need to spend around 70 for a good diagnostic, your computer is going bad! the PCM whatever is called, you should be change it as soon as you can otherwise the car won't be able to start one more time, if you need info, send me an email i will be glad to answer all your questions and give you info for the computer rksnc 05-16-2005, 11:19 PM Quote:Originally Posted by nart86 hi, I'm having trouble with my jeep laredo It cranks but doens't start It takes like 4 times to start but today it took like 10 times in the cold. I noticed that it doesn't start unless the check engine is on. all the other lights come on exept the check engine light. It takes a few times to appear. I don't think it's the fuel pump cuz i hear it clicking immedtly after turning it on. I also don't have any problems with acceleration or idling. I'm going to change either the crankshaft postion sensor or camshaft.... but I don't know which . I recently did a tune up and I have spark. need help asap thanx I just let some mechanic take a lokk at it . He said he needs to dianose it for 75 lol. I checked the codes and got code number 13. does this have anything to do with my problem. I also told him that it might be from the CPS but he doubted it saying that it has nothing to do with the check engine light. and that it would never start up. He said it might be the computerbut i don't trust him lol. as i said my car doesn't start until it sees the check engine light and the mechanic says it always has to be on and that the CPS doens't effect the check engine light. This is what I replied to. Not prestonb If you will see there have been alot of replies. The computer look at the map when key is turn on as baro reading. After that it is going to look at it as a map sensor. But with the engine doing as it is that could easy make that code happen. I have seen this happen to many times. As I replied I did not think the map has anything to do with the not cranking. I know what it will do to a running engine but guess what . this one doesn't run. macman405 05-21-2005, 06:08 PM I'm going to jump in here and side with adgoitd. I have a 93 JGC. Really beautiful car. Runs nice but last year we had pure hell, getting stranded everywhere. Seems it was worse in the hot weather. The first time it happened we were out-of-town. A Jeep dealership diagnosed it and replaced the fuel pump. $700. Probably was going to go out anyway, but that wasn't the problem. A couple weeks later it did it again. This time, we had a local dealership look at it. They wanted to replace the fuel pump too. I knew that wasn't the problem because you could let it sit there a few hours and it would start up right off. So after some on-line research and stuff, I decided to do all the pull and replace stuff I could that wasn't too high tech. I first replaced the coil. Then I tried disabling the alarm system. Then I replaced the CPS. I also replaced the Idler valve. Finally, I replaced the fuel pump and ASD relays. Then fall arrived and it seemed to be fine. All winter it's ran fine. Then today, the first day with temps in the 90s its back to its old form. I believe its the PCM shorting out due to high temps. So I'm going to replace it. I'll let everybody know how it works out. cookie2 05-22-2005, 04:55 AM Not to appear really stupid, but what is a PCM? StacyB 05-23-2005, 12:17 PM It was the computer! $130 (plus core) from Schucks for the one I needed. Starts right up every time now. The installation was easy. (4 screws, 5 counting the windshield washer reservoir removal) Good luck! PrestonP 05-25-2005, 07:10 PM Good news! It was the computer in my case too! I got a new one from a parts dealer and life is good. My alarm problems also seem to be fixed. Thanks everyone. PrestonP PrestonP 05-27-2005, 11:45 PM Does anybody know something about the need for computers to "relearn"? At times my vehicle runs very smoothly, and at other times it gets choppy, the Jeep even stalled twice today! Any thoughts? Any way to help my computer relearn without the rough ride? Cheers, PrestonP mkmcphrsn 05-29-2005, 01:39 PM hi, I'm having trouble with my jeep laredo It cranks but doens't start It takes like 4 times to start but today it took like 10 times in the cold. I noticed that it doesn't start unless the check engine is on. all the other lights come on exept the check engine light. It takes a few times to appear. I don't think it's the fuel pump cuz i hear it clicking immedtly after turning it on. I also don't have any problems with acceleration or idling. I'm going to change either the crankshaft postion sensor or camshaft.... but I don't know which . I recently did a tune up and I have spark. need help asap thanx it sounds like your crank sensor has gone bad rksnc 05-30-2005, 07:30 PM I would go with the crank sensor. Jeeppr 12-18-2005, 09:00 PM I'm having trouble with my jeep cherokee laredo 1994 It cranks but doens't start in morning or cold It takes many times to start. that it doesn't start unless the check engine is on. all the other lights come on It takes a few times to appear. please how do you resolve your equal problem mi e mail is abccafe19@hotmail.com micomputer is # 56027-896 mopar informa the 56028311 is compatible Is the computer mi problem?????? Please help StacyB 12-19-2005, 06:25 PM Yes. Go to Schucks and get a new computer. That was it for me anyway. Easy install. Regards, Stacy I'm having trouble with my jeep cherokee laredo 1994 It cranks but doens't start in morning or cold It takes many times to start. that it doesn't start unless the check engine is on. all the other lights come on It takes a few times to appear. please how do you resolve your equal problem mi e mail is abccafe19@hotmail.com micomputer is # 56027-896 mopar informa the 56028311 is compatible Is the computer mi problem?????? Please help bringselpup 12-21-2005, 04:54 PM X2 Piece of cake to swap. Disconnect the battery + before plugging in the big connector!!!! Troubleshooting: Listen for the fuel pump when you key on. The Computer tells the fuel pump to run for 1 second to pressurize the fuel rail before you start. As mine went bad it would take longer and longer to do that. (Key on not engaging the starter) First it took maybe 15-20 sec and just before it died for good it was taking 15-20 min. If you don't hear that pump spin when you key on you are not going to start no matter how long you crank that motor. You can check if your fuel pump is running by opening the PDC and finding the fuel pump relay. Unplug it and carefully take the cover off the relay and put it back in it's socket. Manually make the relay make contact. Just for a second or two. Have someone in back to listen for the pump. If it's quiet where you're working on the vehicle you may be able to hear the fuel pressurize in the rail yourself if no one is around to listen in back for you. Changing the PCM did it for me. I used a Cardone Reman from Advance Auto Parts. $210 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
