f-150 door panel removalmwhitt1218 08-14-2004, 07:28 PM Does anyone know how to remove the passenger door panel in a 2001 ford f-150? Mike rivguy 08-19-2004, 09:53 PM with power windows - pull up on the switch plate and remove the screw behind it - pop out the rim around the int. handle and remove the screw holding the handle on - pop the trim pannel on the rear of the window off and remove the screw behind that - then lift the pannel up and it's off vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
