MSD Super Conductor Wires vs HotwiresDeleriouS 08-12-2004, 03:20 PM Which of these ignition wires are better? The 8.5mm MSD Super Conductor wire or the Nology Hotwires? integrasedan 08-15-2004, 02:51 PM If you want to spend in the MSD, Hotwires price range, I would recommend Magnecor wires instead. Or I think you should try Accel or NGK wires instead and save money. BullShifter 08-16-2004, 12:49 AM It wont really matter with a stock ignition system. If your pretty much stock (I/H/E) stock ignition a $20.00 set of NGK's from www.summitracing.com will perform just as well as $180.00 Nology's. :2cents: civickiller 08-18-2004, 11:27 PM stock oem is the best Esky 08-19-2004, 12:48 AM vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
