Running problem with 89 GLI
Google
Web AF
Bighit5
08-07-2004, 02:06 PM
My 89 Jetta GLI started acting very strange at stops recently. After I drive it about a mile, when I come to stop and let it idle, it will drop down to 400 RPMs and then rev itself back up to 1200 or so and continue to do this a few times. Once it gets up to temp then it stops doing that. I have also noticed that when I turn on the a/c it will stop it as well.
Also another problem, occasionally it will run like it has no power. I ride dirt bikes and it reminds me of a dirt bike being on choke. Maybe the oxygen sensor?
Any help is appreciated, thanks
pj18674
09-10-2004, 01:39 PM
ck exhaust, You may be having back pressure problems. Mine does this at times.
mark_y
08-27-2007, 06:57 PM
what do u mean by back pressure problems
Doug Tatham
09-06-2007, 02:58 PM
Clean your idle stabilizer valve with carb cleaner. It's a very common problem.
Doug Tatham
09-06-2007, 02:59 PM
Clean your idle stabilizer valve with carb cleaner. It's a very common problem. As far as the loss of power is concerned, I'd check your fuel pressure.
Google
Web AF
