95 Neon engine surges at 50 mph
RogerRoger
08-01-2004, 10:22 AM
My daughters Neon surges at around 50 mph, or when rev'd to about the same rpm when sitting in the driveway. It runs nearly perfect until the rev's are high enough and then begins to cut-out, almost like someone was rapidly pumping the accelerator.
I've replaced various items at the suggestion of others, including:
Throttle position sensor
Crank sensor
MAP sensor
plugs
wires
coil pack
Any thoughts?
Thanks,
Roger
ol yeller
08-01-2004, 03:41 PM
Fuel filter maybe
neons.org
Go there those guys can help ya
larry ais
08-08-2004, 05:50 AM
Hey Rodger, I have the same problem, but my neon is a 96 neon, and when it starts to pull back and forth my speedometer start to move crazy. It moves from 50 to 100 and to 20 and 80 its crazy. I did change the same thing you did but didnt work, we should take ol yeller's advice.
ol yeller
08-08-2004, 10:38 AM
if the odometer is jumping as well could be an altenator problem or short somewhere.
larry ais
08-09-2004, 02:32 AM
Thanks ol for your advice, I will go ahead and check them both. I'll keep you posted.
