code 51
W00dy
07-31-2004, 03:26 PM
I have a 94 Geo Metro for the last year or so my check engine light has come on and i get a code 51. What is this code and what needs to be looked at?
Thanks
Thanks
geojim
07-31-2004, 08:15 PM
EGR vacuum switching valve solenoid.
Book says:
"Closely check all vacuum hoses to the throttle body and the EGR valve. Also check the MAP sensor vacuum hose for leaks or restrictions. In "closed loop" operation with EGR enabled, the ECM will periodically turn "OFF" the EGR VSV. If the corresponding manifold pressure change is less than a calibrated value, the ECM determines that a falult exists in the EGR system and sets a Code 51"
Book says:
W00dy
08-01-2004, 04:17 PM
Thanks
W00dy
10-09-2004, 03:10 PM
Ok I checked all vacuum hoses and I still get a code 51.
What do I look at next?
lawbob81
10-23-2004, 01:31 PM
Check the coil wire, as a poor connection can cause high resistance, wh ich will trigger the code 51. Make sure its' good leading into the distributor cap. Check the cap for quality, if bad, replace the cap and rotor. If your coil isn't putting out good volts, then replace.
Torqued
11-15-2004, 12:49 AM
I recently bought a 95 Metro 1.0L 5-speed. It had several codes stored but after resetting the ECM code 51 comes up again after 10 - 15 minutes of driving.
I saw a list of codes that doesn't match what is stated above for a code 51. Can someone please post a link to an accurate list for a 95?
Thanks
Thanks
W00dy
11-17-2004, 03:32 AM
I replaced the EGR valve and i no longer get a code 51
Torqued
11-17-2004, 03:42 AM
While waiting for an answer to my post, I went ahead and took the EGR valve off and cleaned out the ports. The larger of the 2 hose fittings was plugged with carbon and a drill bit was needed to clear it. (Turned by hand of course). All fixed. No more code 51.
