o2 sensors (purpose)
YBNRML
07-30-2004, 10:21 PM
WHat is the purpose of the upstream and down stream 02 sensors? DO the upstream sensors adjust the air fuel mixture?
Jeremy-WI
07-31-2004, 07:18 AM
The two sensors closest to the motor are used to adjust the A/F ratio and the post catalytic sensors monitor catalyst efficiency
YBNRML
07-31-2004, 08:08 AM
DO you think removing the converters would cause my computer to adjust the air fuel mixture or will it just through a code from the rear sensors. My thinking is if the converters are removed the computere simply sneses that the converters are no longer working and should not effect the air/fuel mixture. Jeremy does this sound logical??
Jeremy-WI
07-31-2004, 11:38 AM
It should only affect backpressure in the exhaust system along with the code for no cat. A lot of people run without a cat and just put up with the code. Random technologies is supposed to make a good high flow catalytic
YBNRML
07-31-2004, 05:34 PM
Do you think I would lose much performance without the cats or would I gain mpg and some performance???
