Car shakes when I brake only between 90 to 80 km/h
Google
Web AF
FARHAD
07-30-2004, 04:44 AM
My 97 BMW 528i shakes when I brake only between 90 to 80 km/h.
Can someone please explain what is the problem? Rotors, wheels or smthng else?
Thanks in advance,
Farhad
Antiburn
07-30-2004, 06:56 AM
You know when the last time you had a brake job done? That might tell you something if its been a while.
hurley9192
07-30-2004, 11:07 PM
I had the same thing on my 97 528...turned out to be the rear bushings needed to be replaced.
3bimmers
08-01-2004, 08:00 AM
It could be the brakes, but most probably the front control arm bushings are shot. Inspect them for cracks. Original rubber bushings give out periodically; replace with urthane for better handling and longer life. Also, torn dust boots on the ball joints indicate need for replacement.
Andy
server_bmw
08-25-2004, 11:36 AM
Your control bushings are done man. However, braking from 90-80 downwards must be done firmly in order to stop the shaking and to brake safely (Try that). If not, then your front rotors are warped.
Thanks
server
gomer12
08-28-2004, 12:06 AM
i would suggest either getting new rotors or gettin the old ones recut
Google
Web AF
