Condensation Leakhydro 07-29-2004, 04:07 PM I noticed soaked a soaked floor board on the passenger front as well as in rear. I discovered that the condensation from the a/c coil is leaking into the passenger compartment. I attempted to gain accesss to the discharge piping, but the only access I can find is thru the inspection port of the blower. It appears that the condensation builds up in the blower housing until it leaks out around the seal in the firewall and/or blows thru the vents to the back seat. I have blown the tube clear with air and attempted to seal the gasket thru the firewall but still getting wet feet and the car smells bad! Understand that Jeep has had a problem with this issue with the solution being to remove the dashboard :(. Anyone have a better solution? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
