Power Loss Problem Toyota 4runner 1999 lmtjoneswoods1 07-29-2004, 01:47 PM I start my car then within 1 to 2 seconds it begins to loose power then it turns off. If I start my car then press the gas pedal it will stay on what is the reason for this is there a part in my car that is faulty or possibly going bad any advice will help. By the way everything was working fine until a headlamp went out then I replaced the headlamps and I also pulled several small fuses to inspect them after this the car began to have problems with power loss. Brian R. 07-30-2004, 10:18 AM Is your "Check Engine" light on? If so, get the ECM error codes. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
