94 S10 Vortec starter wont' engageRussw 07-27-2004, 03:23 PM My 94 S10 4.3 Vortec Starter won't engage, I have swapped Batteries, cleaned and tightened the cables with no results. Is there a starter relay or starter fuse ?? Any suggestions appreciated Russ dwinthrup 07-29-2004, 01:21 AM can you heard starter hum when u turn key? if so hit it with a hammer. or remove it to see if its no jammed smokey041369 07-29-2004, 09:33 AM sounds like you have a starter solenoid problem ( this is part of your starter) rcapprob 10-16-2004, 05:17 PM I'm new to the automotive repair. I can't figure out where the starter is on my 94 s-10 Mikado14 10-16-2004, 05:28 PM Under the motor, on the passenger side. If you do hit it with a hammer, just don't hit the terminal with the big wire. Russw 11-25-2004, 03:59 PM The starter problem went away after setting for weeks, the truck then started and ran OK for a couple monthes and now the problem has returned. I Bypassed the Locktronic system thinking that might be the problem. Should I get a 12 Volt reading at the selenoid purple wire when turning the key to start postion ? If so would this mean a bad starter/selenoid? Is changeing the starter a nightmare on this truck ? Thanks BlazerLT 11-26-2004, 06:36 AM Check your battery coltage with and without the truck running. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
