idler pulley 3.8dyrness 07-24-2004, 09:13 PM My idler pulley arm for the serpentine belt is cracked and the spring can't hold the pulley tight. I looks like the arm itself can come off. There is a star shaped nut then the arm. Any ideas how to get the arm off so it can be replaced? paulkramer 07-26-2004, 11:50 AM I am wondering the same....my 3.8 idler pulley is too loose and I need to replace it....don't want the darn thing to break or seize!! dyrness 07-26-2004, 02:38 PM I am wondering the same....my 3.8 idler pulley is too loose and I need to replace it....don't want the darn thing to break or seize!! I ordered the part from NAPA including the whole arm assembly and it is factory attached to the water jacket under the alternator soe the entire deal has to be replaced. The Pulley, the arm/spring and the water jacket was all $85.00. But a big project to replace. Brad paulkramer 07-27-2004, 09:35 AM I only need to replace the pulley - the arm is ok. I don't think this is a big job - once I figure out how to remove the bolt! dyrness 08-01-2004, 03:53 PM I only need to replace the pulley - the arm is ok. I don't think this is a big job - once I figure out how to remove the bolt! The bolt is reverse threaded. paulkramer 08-03-2004, 11:38 AM Sure is.....thanks! thunderloop 08-22-2004, 01:13 AM At least you know yours is about to go kaput. Mine sheared off ('98 GL) on our way home from the Pima County Fair (April 2003) and we had to be towed into Tucson. paulkramer 08-23-2004, 09:26 AM Wow! What a bummer! Well, I heard it coming....actually, it was the A/C compressor clutch bearing that was making the noise (every 3 years it seems) but it lead me to check everything under the belt... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
