No fuel- intermitent- please help
89v6toy
07-24-2004, 05:29 PM
My 89 V6 pickup (2wd, EFI, 3.0L) ins't running. It has spark but not fuel.
It will sometimes start then die a few minutes later and not start again. The efi fuse under the hood is good. The efi relay clicks when the key is turned on. I bypassed the efi relay with a shunt wire and it did not start. The fuel filter (along the frame, under passenger door) is new. I bought a code checker and it says nothing even tho the check engine light comes on.
Any ideas or suggestions? Thanks in advance.
ketco5
08-26-2004, 06:32 PM
if you do what this says your fuel pump will run whenever the key is turned on.
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
natenelsen
09-19-2004, 05:00 AM
did you figure this one out yet? What did you do to fix it?
Nate
