Im about to start my install but need some help!eld101 07-22-2004, 02:38 PM I just got an 01 pathfinder yesterday and I want to start installing my system but I have some questions that need answering first. 1. Where is the best place to run 0 gauge wire through the firewall and to the back. 2. I am going to put my sub amp in the storage area under the cargo area but I cant seem to find a stealth place for my highs amp. It seems slightly to large to fit under my seats. Any other areas to check? 3. Untill I get my new HU, I want run my sub amp off the line level inputs. I was looking at the bose amp in the left side of the cargo area but what wires can I tap for a low voltage signal? Thanks in advance for the help! Eric mfinzel 08-09-2004, 09:25 PM 1. On the driver's side, follow the lead for the clutch line pass-through. There is a large enough hole there that you can actually see light through it, very easy to use. That should work. 2. You might try under the rear seats, if I recall there's a pretty large space there when you flip up the seat. Other than that, you might be stuck. 3. I don't think this is recommended. Check out the FAQ's on this site for more info about trying to hook up aftermarket components to your factory system: http://carstereohelp.net/gotquestions.htm If I were you, I would just wait until you have your new HU. It *might* work the way you're thinking, but I've found factory bose systems to be pretty finicky. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
