Help with 91 caprice keyless entry
Google
Web AF
FRANKSnBEANS
01-31-2002, 02:20 AM
Does anyone know how to program the remotes for the keyless entry for a 1991 caprice?
Tireburner
02-04-2002, 12:10 PM
Sorry, my books don't go back that far. :mad:
I will keep my ears open for you though.
Rich
02-22-2002, 08:40 PM
DUDE!, you got a caprice? Glad to have you abord. :)
Welcome. I am also currently looking for the re-programming for a 91 (my keyless system is out of a 91 even tho my car is a 93). Im going to be getting my hands on a shop manual this weekend for a 91. I dont know if it says in there about how to re-program, but if it does, ill be sure to post it up for ya
FRANKSnBEANS
02-23-2002, 01:18 AM
hey. hope it has the directions in there. thanks for posting to let me know that you might be getting it.
NeoFreek
03-02-2002, 09:44 PM
Some cars will actually have directions for reprograming the keyless entry some where in the car. Try looking in places like the doors, in the glove box and in the trunk. Thats how I learned how to reprogram other different cars.
My Caprice is to old for me to look in my manual to help you out very much.
Rich
03-05-2002, 03:53 PM
I finally got the rest of the shop manuals that I wanted (they were free!, thanks to a good friend at a dealer. There a bit dirty, but still in good shape and I couldnt pass up the price :D )
Anyways. FRANKSnBEANS This is how you program the Keyless Entry for a 91 Caprice straight from the service manual. I have not got a chance to try it yet as I have been busy. If you need more help with it, I might be able to scan some of it from the manual.
One or two transmitters may be programmed. When 2 transmitters are to be programmed, they must be programmed during the same program sequence [see below procedure]
1. Open the luggage compartment lid. [Trunk]
2. Access the programming connector. [ In the diagram it appears to be on the left-hand side of the car in the trunk, is attached to the wiring that runs to the rear left lights, but is a small connector with only 2 terminals. If it is too unclear (I apologize for the bad description), pm me and ill try to scan it for ya.
3. Jumper the 2 terminals together using a fused jumper. The door locks and trunk solenoid will cycle indicating the reciever is in program mode.
4. Press any button on the transmitter (only once). The Keyless Entry Module will cycle all the Door Lock Motors and Trunk solenoid once. Any transmitter code that was previously programmed is now erased.
5. If a second transmitter is to be programmed, press any button on the second transmitter once. The Keyless Entry Module will cycle all the Door Lock Motors and Trunk solenoid once.
6. Remove the fused jumper from the Keyless Entry Programming Connector.
Enjoy :)
Google
Web AF
