A/C RPM Problem
Civic XZ
07-21-2004, 07:58 PM
I have a problem when, i turn on my A/C, The RPM Come to low and when i am in a stop the car die, then i need to turn on one more time, the car temp. is really good, i dont know what happend to my car, its a DX HB 1992 whit original motor, it have like 215,855 miles(i put in it a enso doble platinium spark plug, cilicon 8.0mm cables almost all service in time ) what should be the problem?? :disappoin
i_a_n112784
07-21-2004, 10:53 PM
First of all, there is this language called english. At least try to use it. Secondly, there should be a solenoid or similar device that boosts the idle when the a/c kicks on.
exman98
07-21-2004, 11:18 PM
dont use your A/C
i just like the windows rolled down and it always works fine.
also my car never dies when i turn the windows on oopps
i mean roll them down
exman98
07-21-2004, 11:21 PM
sorry for being an ass
but if you try to rev you engine at a stop does it still die
any ways with a car with that much wear you should still be happy to drive it
svang8
07-22-2004, 02:02 AM
evertime a car turns on ac the rpm drops lower. thats a normal thing..what you can do is turn your idling knob at throttle body bigger for more air flow and adjust your throttle cable tighter so that the rpm doesn't drop too low to cause your car to die....
