Is It The Alternator???
Google
Web AF
Zudnick
07-21-2004, 07:11 PM
Hey,
I have a 1996 Blazer 4.3 and a week or so ago I started to notice a whirring or humming type noise coming from under the hood. The noise seems to match RPMs, but isn't very loud... it is most noticeable when sitting at a light or driving slow -- much faster and engine/road noise drown out the humming.
Now, I have noticed that the Voltmeter is running very low. It's normally right inthe middle of the gauge at about 14 (right ?), and now it's almost down in the red (but not quite).
I'm thinking that it's probably the alternator... what do you think?
If it matters, I haven't really noticed any performance change, and it does still start fine and will run the lights, radio, etc with no problem.
Thanks for the help.
Z
mike2004tct
07-22-2004, 07:05 AM
Sounds like the alternator is going bad. You'll know for sure if your gauge doesn't go above the 12V mark at driving speeds and your battery will eventually drain/die.
If it were only a bad/loose belt, you'd notice the difference in the power steering.
bobmga62
07-22-2004, 03:00 PM
DYES, I AGREE ON ALTERNATOR AS WELL...
before finally loosing mine, I had a signaificant "whirring" fearing noise before the alternator departed..
What was worse I was towing my race car about 800 miles home... I hwas hopping it would make it... whicih it did.. then died about two days later...Luck was on my side, for a change...
R
Google
Web AF
